xenon
Question For Taking Night Pictures.
Fri Dec 13, 2002 1:00 pm
Hi,
My question is: what can be done to that yellow shine when taking night pictures?
Or...is it just normal when you shoot with a longer shutterspeed?
Maybe a filter or so?
I uses a Olympus C2100UZ.
some examples:
Photo © Daniel Alaerts
Many thx for any advice,
Daniel
AirTeamImages -ATI-
clickhappy
RE: Question For Taking Night Pictures.
Fri Dec 13, 2002 1:04 pm
it depends on the lighting. Most airports use those awful yellowish lights, but some, like YVR, use the really bright white type, I think they are mercury vapour lights. Anyways, the color tone of the picture should be dictated by the color of the light source.
xenon
Fri Dec 13, 2002 1:10 pm
Clickhappy:
So you think the yellow shine isn't disturbing the rest of the picture?
Thx,
Daniel
AirTeamImages -ATI-
thomasphoto60
Fri Dec 13, 2002 1:12 pm
Indeed some airports use mercury vapour lighting while others use sodium vapour and some still use fluorescent. You can buy a number of filters to remedy this problem, however these can be a pain. I suggest using Photoshop or whatever imaging program you prefer and correct it there.
Thomas
"Show me the Braniffs"
PPGMD
Fri Dec 13, 2002 1:20 pm
Xenon,
You asked for help so I spent a moment in PS.
Converted the picture to CMYK
Went into curves
Pulled down the top end of the yellow to where the picture looked right.
Converted back to RGB
Resized it
One thing that you can do in camera so you don't lose dynamic range, set your white balance.
At worst, you screw up and die.
xenon
Fri Dec 13, 2002 1:27 pm
PPGMD:
So the yellow on the tarmac is gone but so is the yellow from the plane...
You think A.net would accepted the picture like this?
Thx for helping,
Daniel
PS: What with that white balans
AirTeamImages -ATI-
res
Fri Dec 13, 2002 1:29 pm
I notice your Olympus has the same problem as mine...it has that green dot in the same place on every picture. I clone them out with my photos though. Its visible in the lower right quadrant, somewhat close to the center.
FLY NAVY
xenon
Fri Dec 13, 2002 1:33 pm
Guys,
Can't reply anymore for the moment. Have finished on my work so I go to bed!
See you later!
Thx for helping me!
Daniel
AirTeamImages -ATI-
PPGMD
Fri Dec 13, 2002 1:36 pm
White balance sets the colors tones for the lighting types, weather it's red tint of light bulbs or the slight blue tint of speedlights. As far as being accepted you lost alot of dynamic range by not setting your white balance in camera, so maybe not.
Lear45
Fri Dec 13, 2002 6:53 pm
Daniel
You need to change the white balance setting, and experiment with whatever the C-2100uz has (tungsten ??).
I used to own a C-2100uz but actually got rid of it because it wasn't able to take 'right-looking' night shots however ;,-(
Andy
Jofa
Fri Dec 13, 2002 7:28 pm
PPGMD
"Converted the picture to CMYK"
Why would you want to do that and loose alot of colorinformation?
RGBs colorspace is ~16 million colors while CMYK is only a couple of thousand.
That means all colors not printable will be converted to printable ones once you choose CMYK, giving the image a faded, greyish look.
I would suggest keeping it in RGB and choose Adjust-->Selective Color.
Jormy
Fri Dec 13, 2002 10:52 pm
Well, here's how I deal with that yellow-cast "problem":
1. First of all, you need to have a RAW capable camera to do this.
2. Take a picture with auto white balance/tungsten settings and the resulting image looks something like this (yuck  Sad):
3. Bring the RAW to somekind of a converter where you can set a custom white point.
4. Select a white point from the picture (usually planes body is good unless the plane is not white)
5. The resulting image should look somewhat nicer:
Photo © Janne Laukkonen
If you don't have a RAW capable camera then I suggest to try some color-correcting filters. 81A, 81B and 81C are good filters to start with...
-Janne
cabbott
Sat Dec 14, 2002 12:24 am
Janne
I just played around with a shot which was similar to yours in tungsten colours.
Used ACDSEE auto balance and wallaa...
Photo © Europix
Colin
Jormy
Sat Dec 14, 2002 1:02 am
Colin,
looking good... didn't know you could have that nice weather in the UK...  Wow!
-Janne
photopilot
Sat Dec 14, 2002 3:06 am
Colin:
Love the texture the snow gives to the "sky" with the shining lights. Well done shot.
Steve
LGW
Sat Dec 14, 2002 3:38 am
Janne...great shot and amazing the difference between the two shots...don't let Vasco see all this editing, like his World MD11 shot...all shots should represent the actual conditions so if the shot is ruined by horrid yellow lightsthen so be it and upload anyway Big grin
j/k Vasco
LGW
PPGMD
Sat Dec 14, 2002 5:00 am
Jofa,
I send most of my stuff out to print so working in CMYK is natural for me. Besides the selective color interface seems a little slugish, it's much easier working with the curves. But you know what I have never seem any major issues with picture quality after converting to CMYK, which I do routinely for shots that I need that extra bit of control.
But the easiest way would be to just set your white balance so you don't even have to do any editing.
Jofa
Sat Dec 14, 2002 7:26 am
PPGMD
Converting to CMYK and then printing makes sence, but converting them back to RGB and using for the web decreases the quality whether your eyes see it or not.
Since everybody is striving towards better quality i think it's important to point this out.
