jcs17
Resolution For Film Scanners
Sun Jan 05, 2003 4:56 pm
Quick question, what is a good resolution to get on a 35mm film scanner.
Josh
America's chickens are coming home to rooooost!
Joge
RE: Resolution For Film Scanners
Sun Jan 05, 2003 8:25 pm
Hey, Josh...
If you go for a film scanner (not a flatbed scanned with a film scanning option), any scanner should be ok, as the cheapest one available can do 1800 dpi (check the next link):
http://www.aaacamera.com/primefilm_scanner_1800s.html
But for possible image cropping and bigger prints more is recommended, of course.
1800dpi * 1½ inch wide slide/negative frame = 2700 pixels wide image on your puter. For a print at 300dpi it's enough for a photo 9 inches wide.
However, the scan quality and dynamics are quite poor on that scanner, so it's not just the resolution that matters.
-Joge
Bula!
Users browsing this forum: RedSnapper and 1 guest
