RWY-16
Best Window Seat In An Avro RJ-85/RJ-100
Fri Jan 10, 2003 6:34 pm
What are the best window seats in an Avro RJ-85 and RJ-100 for taking pictures out of the window?
Thanks for your answers.
Kind regards, Andi
Joge
RE: Best Window Seat In An Avro RJ-85/RJ-100
Fri Jan 10, 2003 7:02 pm
Get as front or as rear as you can. Sitting under the wing means that the engines will block the view. Also you'll get huge amount of steam spoiling the photography abilities if your seat is right after the wing.
-Joge
Bula!
derekf
Andi
Foward of the wing if you want to take pictures of the ground as you will get the heat distortion from the engines aft of the wing, however you get good views of the flaps etc.
Derek
Whatever.......
Sabena 690
Fri Jan 10, 2003 8:05 pm
Don't take row 10 in an Avro RJ100, I repeat, no row 10 in an RJ100!
When I boarded my first ever Avro RJ100 flight in September (SN Brussels Airlines), I figured out that this was the row without a window  Crying
Unfortunately enough it was already too late to change seats  Sad
Frederic
MUC-PIX
Fri Jan 10, 2003 10:28 pm
Hey Sabena690, those are the moments... too bad. I would also say: Choose the very front or the very back and have nice wing-including shots.
