lugonza_2001
Scanning Slides, Need To Unframe Them?
Sat Apr 26, 2003 2:57 am
Hi!
Today i have seen a Canon 660 U scanner, that features slide scanning, my doubt is if you have to unframe the slide in order to get it scanned.
Thank You!
jderden777
RE: Scanning Slides, Need To Unframe Them?
Sat Apr 26, 2003 4:20 am
not sure what that particular scanner requires, but on mine it has an adapter both for slides (mounted) and negatives....if i have the slides done "process only" they end up on long rolls like negatives, and i can scan them in the negative adapter....but i don't have to take the mounted ones out in order to scan them, as should be the case with your scanner...
good luck,
jonathan d.
"my soul is in the sky" - shakespeare
