AA727
Teleconverter Troubles
Fri May 09, 2003 7:56 am
I just got a Vivitar X2 AF and I'm having troubles already. I looked through the manual, didn't find much. The problem is that when i try to change shutter speeds, aperature setting, etc...the display begins to flash OFF. Also, the AF seems to just be slightly off, but that may be due to the cloudy wx. I'm going spotting tomorrow, so any help before then would be great! Smile/happy/getting dizzy
Sean
2912n
RE: Teleconverter Troubles
Fri May 09, 2003 9:06 am
What type of camera and lens are you using? That would help.
AA727
Fri May 09, 2003 9:27 am
Sorry about that, I was on my way out of the house. So, I was trying to post something about it quick. I'm using a N65 and a Tamron 75-300mm lense.
JeffM
Fri May 09, 2003 3:10 pm
Sean,
Unless the Tamron 75-300mm is an f4 or faster lens, the AF may not work at all, thus the flashing you are talking about. Manual focus should work well at any rate.
v/r
Jeff
Users browsing this forum: No registered users and 16 guests
