RyDawg82
Inflight Shots From The Flight Deck
Thu Jun 19, 2003 8:38 pm
Hello.
I was curious if anyone can provide me with some tips. How can I take good shots from inside the flight deck while inflight? I have read the following post http://www.airliners.net/discussions/aviation_photography/read.main/92042/ -- However those tips would be for while on the ground. Today I was taking photos from a 737-900, either bright outside, dark inside, or vice versa. Is there any way to balance the two? I got close on some shots, it just seems like I could do better.
Oh and Im using a Sony F-707 - if anyone was going to ask....Thanks for the help....Ryan
RyDawg82
RE: Inflight Shots From The Flight Deck
Mon Jun 23, 2003 3:26 pm
Can anyone please help?
Ryan
brianhames
Mon Jun 23, 2003 3:35 pm
Ryan,
Yup, there is a way to fix that problem you talked about. What you need to do, is use the flash. When you take your light reading, take it outside the cockpit, and then use that setting with flash on, so the flash will illuminate the flight deck while the outside looks normal too.
Photo © José Rodrigues
Photo © Dmitry Avdeev
Brian
RyDawg82
Mon Jun 23, 2003 4:02 pm
Hey Brian,
Good to hear from you, long time no see....
I read about that method to improve flight deck shots, its just that I don't feel comfortable having a bright flash going off while on short final into say Juneau in a 737-400....Is there any other settings or conditions that seem to help?
Ryan
