s.p.a.s.
Filter To Correct Orange Effect...
Thu Aug 28, 2003 9:55 am
Hi folks...
Some airports don´t have white tarmac lamps but yellow/orange ones leading to some results I personally don´t like, i.e.
Photo © Micheil Keegan
I know of a filter which reduces this yellish hue..but don´t know it´s code...anyone there could shed some (white..) light on this?
Renato
"ad astra per aspera"
JeffM
RE: Filter To Correct Orange Effect...
Thu Aug 28, 2003 9:57 am
Renato,
Not an issue if you shoot digital. Just set a custom white balance. For film, you will need to find out the temperature of those lights.
Jeff
s.p.a.s.
Thu Aug 28, 2003 10:02 am
Thanks so far Jeff...and I´m (still) making film...
photopilot
Thu Aug 28, 2003 12:49 pm
For color correction from 3200K Tungsten lighting to Daylight balance film (5200K) you need to use an 80B filter. There is also an 80A and an 80C which are slightly lighter and darker respectively.
You must also be aware that some airports are using a Sodium Vapour type lighting (which also looks yellow) for economical reasons, but this Sodium lighting is almost impossible to filter correctly because of it's very narrow light spectrum.
Basically, to eliminate yellow cast, you need to add either Blue or Cyan filtration. A color temperature meter which also gives color correction factors is the only real way to get accurate results with film. Of course if you have the meter, you also need a box full of CC filters to use with the readings.
Good luck
Steve
s.p.a.s.
Fri Aug 29, 2003 10:53 pm
Hi Steve..
Thanks for the valuable information mate... Will take a closer look on those 80´s series filters
Renato
mas a330
Sat Aug 30, 2003 12:20 am
I changed the colour balance of the photo above to about 9300K and got quite good result.
Users browsing this forum: 727LOVER, jupiter2 and 1 guest
