PUnmuth@VIE
BRU Info For This Sunday?
Fri Aug 29, 2003 6:22 am
Hi all!
I am going to BRU on this sunday (31st of August). is there any cahnce to get the SB Brussels 330's on Sunday. And could any of you give me informatrion about the spots and nearby parking lots or parking possibilities?
Peter - VAP-Group
ericbelgium
RE: BRU Info For This Sunday?
Fri Aug 29, 2003 8:47 am
Peter,
next time you are planning a trip to Brussels, let me know some 10 days in advance; I'll be happy to drive you around, we have some véry neat spots indeed  Big grin
Unfortunately I have to work, by doing so ironicly enough I will be on the freightside of the airport 3 to 4 times, unfortunately only for a brief moment...
But since there a load of Belgian freaks can be found here on Anet, I'm sure you'll get you part of good ol' belgian hospitality....after all this is thé country of the best beers  Innocent
greetz, Eric
Sabena 690
Fri Aug 29, 2003 5:53 pm
Hi Peter!
BRU photography: you have to be by car, otherwise forget about it  Sad
But there are some exceptions for take off photography.
We have 2 neat spots:
1) the bridge at Sabena House:
Photo © Ivan Coninx
Photo © Ivan Coninx
2) the Brucargo spot (basically the aircraft rotate and fly overhead you):
Photo © Ivan Coninx
Photo © Ivan Coninx
How you get there:
When you are in the arrivals terminal, go outside. Walk to the left. About 200 metres further, you have a fence from where you can see Sabena Technics. On your right you have the car park, with just in front of it, a busy road. Make that you are on the footpath of that road (make that you don't take the wrong road, you have one on the side of the airport and one on the side of the car park. It's the one at the car park). When you are good, you will be on a foodpath with a small fence on your right side, to protect you from the cars. Follow this, it's quite long (certainly 500m). To check if you are good: all cars drive in the opposite direction of you (so for cars it's a one way direction) and the road has 2 or 3 sections. SN Technics, Sky Chefs (catering) etc will be on your left side. Follow untill you are at a bridge with a roundabout. Go right over there, cross the first street, walk under the bridge, cross the second street and there you enter a road which will lead you to DHL and Abelag (bizjets). Follow that road. If 25R is in use for take offs, you will see the aircrafts take off, and on your right side you will see several DHL's parked and bizjets. Continue, you will pass the Sobelair buildings and Sabena House. Continue untill you see the bridge over the 'highspeed route' or how do you say that. At the bridge, you have the first spot. If you want to see Brucargo (with normally Eva Air, Saudi Arabian Airlines Cargo, Singapore Airlines Cargo etc) + if you want to take rotate shots (make that you have a good zoom), go over the bridge, the road makes a right turn, follow the road past the houses and take the first road on your right when you have passed all houses (about 150 metres from the bridge). There is also a sign 'De Mosselbank'. Follow that road upstairs, to check if you are good: on your left side it should be all grass. Follow untill you reach the fence. There you can install yourself  Smile/happy/getting dizzy
I hope it's clear, feel free to ask further questions. Movements: check http://www.brusselsairport.be on saturday evening.
I will not make it to lead you around, hopefully somebody else can! Because the best spots are landing spots, but without a car: forget about it.
Frederic
PS: why did you go on Sunday? BRU is quite silent on sundays... and they predict a lot of rain  Sad
ebos
Fri Aug 29, 2003 6:04 pm
Hi Peter,
SN Brussels long haul flights to Africa depart around noon.
SN473 Entebbe 10.40
SN203 Dakar 12.25
SN3139 Freetown 13.45
You can download the timetable
http://www.sntimetable.com/SN.pdf
According to the weather forecast (winds from the west) rwy 25R will be in use for take-offs. You only can take them during take-off. Best spot, as Frederic explained, is the environment of the sabena-house. I would advise you to stand on the parking lot next to Abelag (follow the signs general aviation - abelag). Think you need about 350mm for an A330.
Unfortunately i can't make it to BRU on Sunday. Good luck.
Sven
An-225 stalker: 1 x LUX, 1 x EIN, 1 x DXB, 2 x SHJ, 3 x CGN
Sabena 690
Fri Aug 29, 2003 7:49 pm
Some visitors I took from Galileo:
x 2x UA B763
x AA B763
x MS A320 + A321
x MA B73G
x TK B737
x CO B762
x AT: 2x B735, B752
x RO B733
x EI BAe146
x KM B733
x MK A343
x AH B738
x LY B738
x RJ A310
+ a lot of SN, BA, LH, ...
Frederic
Sabena 690
Fri Aug 29, 2003 8:16 pm
http://www.luchtzak.be has a very good aviation section, this link must help you: http://www.luchtzak.be/modules.php?name=News&file=article&sid=50
In my post (I hope it is a bit clear) I was talking (Sven also) about spot C and D.
Frederic
Sabena 690
Fri Aug 29, 2003 8:33 pm
I just looked up a whole bunch of pictures, but when I pressed the post button, the site went offline for a second  Angry
The whole post is lost, I'll look them all up again later today...
donder10
Fri Aug 29, 2003 11:05 pm
Frederic,
is it possible to get photos of Hewa Bora parked up at the gate or do they get parked on remote stands?Are they still flying in Saturday and out Sunday?
Cheers again,Alex
Sabena 690
Fri Aug 29, 2003 11:26 pm
Alex: Hewa Bora parks at the B-Pier. I once managed to get a shot from it when I was in the A-Pier, but photographing aircrafts at their Pier in BRU is very difficult, like everywhere I guess.
The best thing you can do is go to the take off spots explained in this topic, and shoot her there.
But hurry, rumours are going to Hewa Bora will put it's code on SN flights, and will stop flying to BRU! Their loads are very high, but the aircraft is the problem. 9Q-CHA is already grounded and used for spare parts, I'm afraid it's almost the turn of their last one, 9Q-CHC  Sad
Frederic
Sabena 690
Fri Aug 29, 2003 11:33 pm
ALX arrival:
ALX100 -----6- 11:00 19:45 L10 3003-2510
ALX departure:
ALX101 ------7 11:00 17:45 L10 3103-2610
apuneger
Fri Aug 29, 2003 11:41 pm
Peter,
check your mail. I tried to add a big reply, but all I got was this 'Internal Server Error', so I just sent it to you via email  Wink/being sarcastic
Ivan
Ivan Coninx - Brussels Aviation Photography
PUnmuth@VIE
Sat Aug 30, 2003 12:11 am
Hi guys!
Thanks for all this infos
Peter
RayPettit
Sat Aug 30, 2003 5:23 am
It would be a real shame if the Hewa Bora TriStar stopped, and not JUST because its TriStar! However, I did not expect them to be a long lived operator into BRU.
The time surely to have got it was on approach on a summer evening. I visited BRU from the UK last September and saw it land as I drove past - it was way too dark by then but it was still very nice just to see.
Ray
ebos
Sat Aug 30, 2003 7:11 pm
Just read on the kerozen mailing list that rwy07L/25R will be closed on sunday from 12.00 till 17.00 local time.
That means that the spot near the refugee centre along rwy 25L is the best for landings and line-up.
Sven
Sabena 690
Sat Aug 30, 2003 8:22 pm
Hi Peter,
Look at this:
http://www.luchtzak.be/modules.php?name=News&file=article&sid=1381
Getting to the refugee center is impossible, unless you know your way (not very easy) and you have a car.
Now that 25R is closed, I can only recommend you to stand at the car park, facing towards SN Technics. When it is heavy raining, you can go one floor lower. When it is ok, you can stand above, there is no fence and photography of 25L departures should be possible with some nice backgrounds.
How to go: go to the departures terminal before you leave the airport buildings. Go outside, and take the carpark at the left (not the new one at the right). Go to the upper floor, and from there you will be able to shoot some nice pictures.
Frederic
Staffan
Sat Aug 30, 2003 8:26 pm
"Runway 07L/25R will be out of service due to helicopter traffic above Brussels"
If this is the case I doubt 25L will be used for departures??
Staffan
Sabena 690
Sat Aug 30, 2003 8:46 pm
Yes Staffan, because also 02/20 will be out of service in the morning..
Normally, 25L is only occassionally used for a departure (I saw that already from time to time). The problem is that no taxiway goes to the beginning of 25L. So aircrafts have to taxi to the end, backtrack 180° and take off. This takes some time which means that a lot of delays can be expected. Luckily BRU isn't very busy on Sundays but still busy enough to cause troubles.
When 02/20 opens in the afternoon, I wonder which runway will be in use. I think they will avoid to keep everything on 25L, so maybe t/o from 02 and landing on 25L?
Frederic
ILS.25L
Sat Aug 30, 2003 10:15 pm
Take off PM will be one of the possibilities although I think, if the wind is as strong as today, they might have quit some crosswinds for take off. As Sabena690 says, Sunday PM can be very calm so take off from 25L might be an option.
Regards, Karl
Sabena 690
RE: BRU Arrivals Untill 2 Pm Sunday 31/08
Sun Aug 31, 2003 3:18 am
31/08 05:20 Tel Aviv SN 3292
31/08 05:45 Conakry AA 7445 05:45
via Dakar
31/08 05:45 Conakry SN 206 05:45
via Dakar
31/08 06:15 Puerto Plata SLR1888
31/08 06:30 Kigali SN 463
via Nairobi
31/08 07:10 SanFrancisco UA 950
via Washington
31/08 07:10 Washington US 7292
31/08 07:45 Kinshasa AA 7449
via Douala
31/08 07:45 Cancun SLR1862
31/08 07:45 Kinshasa SN 352
via Douala
31/08 08:00 Amsterdam KL 1721
31/08 08:00 Amsterdam NW 8235
31/08 08:00 Paris CDG SN 3626
31/08 08:05 Frankfurt LH 4494
31/08 08:05 Lyon SN 3594
31/08 08:10 Geneva LX 4150
31/08 08:10 Budapest MA 600
31/08 08:10 Geneva SN 2724
31/08 08:15 Prague OK 630
31/08 08:15 Prague SN 5224
31/08 08:20 Newark CO 060
31/08 08:25 Atlanta DL 124
31/08 08:40 Zurich AA 6270
31/08 08:40 Zurich LX 786
31/08 08:40 Zurich SN 4054
31/08 08:45 Chicago ORD AA 088
31/08 08:45 Nice AA 7412
31/08 08:45 Barcelona IB 7786
31/08 08:45 Nice SN 3622
31/08 08:45 Barcelona SN 3708
31/08 08:45 Chicago ORD SN 8002
31/08 08:50 Vienna OS 351
31/08 08:55 Athens TV 401
31/08 08:55 Barcelona TV 801
31/08 09:00 Rome CO / LIRF), Italy">FCO TV 701
31/08 09:05 London LHR BA 4998
31/08 09:05 London LHR SN 3832
31/08 09:20 New York DL 140
31/08 09:25 Bodrum OHY 989
31/08 09:45 Palma Mallor IWD7305
31/08 09:45 Antalya MNB2305
via Dalaman
31/08 09:45 Athens T4 202
31/08 10:00 Amsterdam KL 1723
31/08 10:00 Amsterdam NW 8223
31/08 10:05 Frankfurt LH 4462
31/08 10:05 Frankfurt SQ 2038
31/08 10:25 Munich LH 1970
31/08 10:30 Bodrum PGT 267
31/08 10:35 London LHR BD 145
31/08 10:35 London LHR LH 6701
31/08 10:35 London LHR UA 4822
31/08 10:55 Chicago ORD UA 958
via London LHR
31/08 11:05 Naples PE 8155
31/08 11:05 Naples VA 8155
31/08 11:10 Milan MXP AZ 146
31/08 11:10 London LHR BA 392
31/08 11:10 Madrid IB 3206
31/08 11:10 Palma Mallor SLR6726
31/08 11:10 Milan MXP SN 5002
31/08 11:10 Madrid SN 5258
31/08 11:10 London LHR SN 5392
31/08 11:15 Istanbul TK 1937
31/08 11:15 Nice TV 303
31/08 11:20 Amsterdam KL 1725
31/08 11:20 Lisbon NI 2006
31/08 11:20 Amsterdam NW 8225
31/08 11:20 Bucharest RO 371
31/08 11:20 Lisbon SN 5282
31/08 11:20 Lisbon TP 5006
31/08 11:25 Zurich AA 6222
31/08 11:25 Zurich LX 778
31/08 11:25 Alicante SLR6766
31/08 11:25 Zurich SN 4056
31/08 11:35 Copenhagen OV 6401
31/08 11:35 Copenhagen SK 593
31/08 11:35 Copenhagen UA 9318
31/08 11:45 Rome CO / LIRF), Italy">FCO AZ 156
31/08 11:45 Athens OA 145
31/08 11:45 Rome CO / LIRF), Italy">FCO SN 5020
31/08 11:55 Barcelona IB 4214
31/08 11:55 Barcelona SN 5272
31/08 11:55 Barcelona TV 803
31/08 12:00 Ibiza FQ 783
31/08 12:00 Palma Mallor TV 873
31/08 12:05 Menorca FQ 725
31/08 12:05 Tel Aviv LY 331
31/08 12:15 New York BG 012
31/08 12:20 Munich LH 5924
31/08 12:20 Munich UA 9102
31/08 12:40 London LHR BA 402
31/08 12:40 London LHR SN 5402
31/08 12:45 Manchester BA 4954
31/08 12:45 Manchester SN 2174
31/08 12:50 Stuttgart LH 5888
31/08 12:55 Oran AH 2064
31/08 13:05 Porto NI 906
31/08 13:05 Porto SN 5054
31/08 13:05 Porto TP 936
31/08 13:10 Edinburgh BD 629
31/08 13:15 Madrid IB 7790
31/08 13:15 Madrid SN 3720
31/08 13:20 Dublin EI 634
31/08 13:25 Sevilla SN 3746
31/08 13:30 Prague OK 4636
31/08 13:30 Prague SN 2810
31/08 13:30 Malaga TV 831
31/08 13:35 Lisbon LK 9503
31/08 13:35 Athens SLR1702
31/08 13:35 Lisbon TV 503
31/08 13:40 Helsinki AY 6783
31/08 13:40 Helsinki SN 2334
31/08 13:50 Geneva AY 6624
31/08 13:50 Milan MXP AY 6638
31/08 13:50 Milan MXP AZ 7058
31/08 13:50 Geneva LX 4154
31/08 13:50 Geneva SN 2714
31/08 13:50 Milan MXP SN 3158
31/08 13:50 Nice SN 3618
31/08 13:55 Venice VCE AY 6682
31/08 13:55 Venice VCE AZ 7434
31/08 13:55 Venice VCE SN 3202
31/08 14:00 Brindisi SN 1072
31/08 14:00 Athens TV 403
Sabena 690
Mon Sep 01, 2003 12:06 am
Peter, did you see VP-BAT, the B747SP this afternoon?  Smile/happy/getting dizzy
/Frederic
Sabena 690
Mon Sep 01, 2003 2:52 am
Following biac.be, 02/20 hasn't been closed today.
Take off was planned from R 20.
Peter, I guess you were able to shoot nice t/o pics from the car park?
Frederic
PUnmuth@VIE
Mon Sep 01, 2003 5:27 am
despite the weather it was ok today. 3 Saudia MD-11 Cargo VP-BAT two all white B737 with VT registration, Hydro Air Cargo, Volare all white and some other nice stuff.
Thanks for the information guys
Peter
apuneger
Tue Sep 02, 2003 12:27 am
Hi,
I hope you enjoyed your stay at BRU, Peter. Unfortunately, I couldn't come. Also, the weather was not as good as it has been these last few months. Bummer  Sad
Ivan
PUnmuth@VIE
Tue Sep 02, 2003 1:08 am
Here are the first shots:
Photo © Bernd Karlik - VAP
Peter
Sabena 690
Tue Sep 02, 2003 3:06 am
Very nice pictures, congrats!  Smile/happy/getting dizzy
You're sure about the BA reg?  Big grin
Frederic
apuneger
Tue Sep 02, 2003 3:43 am
Nice pics indeed. Where were those pics taken from? The car park? Maybe Pier A?
And as Sabena 690 mentioned, the Ba 319 appears to be G-BUSG.
Greets,
Ivan
PUnmuth@VIE
Tue Sep 02, 2003 3:56 am
yes its G-BUSG the correction is already sent  Smile/happy/getting dizzy
I guess Bernd was a little tired from hanging around at the fence and garages all day long and from climbing in and out of that smart Roadster we had rented Big grin
Peter
[Edited 2003-09-01 21:02:43]
