MIA777
Advice For Shooting In A Hangar
Sat Sep 20, 2003 4:00 am
I am going to have access to a Biman Bangladesh A310 that was just painted in the new livery at MIA. I am not sure if the plane will be in the hangar or out but if it is, any advice (i need to learn!)? I have never shot a plane indoors and have never been in a hangar (don't know how well they are lit though I would imagine pretty well). Interior shots advice as well? Thank you! This is all greatly appreciated!
MIA777
2912n
RE: Advice For Shooting In A Hangar
Sat Sep 20, 2003 4:36 am
Get a tripod and play with your settings in order to shoot indoors. Such a big target will mean flash won't work so you will want to do a time exposure of several seconds (all depending on the lighting.)
work4bmi
Sat Sep 20, 2003 5:27 am
The MOST IMPORTANT rule of all is to ask if there are ANY exposed engines and/or open fuel lines in the hanger. One flash of your camera could blow up the whole freaking building!
Aaron  Smile
Fly Around The World : Above & Beyond
JoakimE
Sat Sep 20, 2003 5:34 am
Well, at least the entire aircraft would be well lit up then, so no need for a tripod or long exposures  Innocent  Big thumbs up
2912n
Sat Sep 20, 2003 5:36 am
If a sealed camera flash can set off an explosion.....The environment inside the hanger would have to be so dangerous you probably could not survive in there long enough to set up a camera!  Smile
work4bmi
Sun Sep 21, 2003 4:18 am
"If a sealed camera flash can set off an explosion.....The environment inside the hanger would have to be so dangerous you probably could not survive in there long enough to set up a camera!"
funny, but I would not recomend using flash!
G-CIVP
Sun Sep 21, 2003 5:10 am
I think some fire detection systems are set to pick up 'flashes' as in explosions, so ask before you shoot as your flash may inadvertunately set the fire alarm system off. Don't know how true this is but better ask before you commence.
Thom@s
Sun Sep 21, 2003 5:34 pm
Open doors which allow daylight to enter the hangar is always nice.
Photo © Thomas Andre Hjelmen
With smaller aircrafts you might be lucky enough to have it rolled out into the sunshine if the hagar is too dark....
....but that might be tricky if you are dealing with an A310.
Good luck anyway.
Thom@s
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
