Karlok
Help With Photo
Wed Sep 24, 2003 3:35 pm
I got this rejection today.
How should I edit this photo to get it accepted on airliners.net?
http://airliners.net/procphotos/rejphoto.main?filename=ph-bfv_ams_klw_17092003.jpg
ckw
RE: Help With Photo
Wed Sep 24, 2003 5:02 pm
A little dark, excess contrast (shadow areas are completely blocked out) and over sharpened (jaggy cheat lines and halos round the tires).
I'd say its been over-processed ... I wouldn't try and fix this version, but go back to the original and start again.
Colin
Colin K. Work, Pixstel
Jani
RE: Help With Photo
Wed Sep 24, 2003 10:08 pm
Is that really taken with Reala 100? I thought it was digital at first! So sharp! What equipment are you using?
I am using Reala 100 too, but never get these kind of results in the aspect of sharpness...  Sad
Karlok
RE: Help With Photo
Wed Sep 24, 2003 10:42 pm
Yes it is Reala 100, taken with a Nikon F65, 70-300mm lens,
bigphilnyc
RE: Help With Photo
Wed Sep 24, 2003 11:16 pm
That's a nice shot with good potential.
I thnk your biggest problem is errored color. Use Color Balance and slide the bar away from the green a littl bit until you think it's just right. I'd bet an adjustment of about 15 would do the trick. Just do it until the gray on the bottom of the plane is at a nice true gray, and then youll notice that the white stripe and the blue also look fuller.
SOME people would also mask the sky and adjust the color and/or brightness. Just some people, not that I condone that. hehe. lol
-Phil
Phil Derner Jr.
EGGD
RE: Help With Photo
Wed Sep 24, 2003 11:54 pm
Yes, oversharpened and bad compression, make sure you set it at the highest quality when you are saving it.
Maybe add a little blue/red as well.....
Karlok
RE: Help With Photo
Thu Sep 25, 2003 4:13 am
Roger that, with these information I can work on it.
clickhappy
RE: Help With Photo
Thu Sep 25, 2003 4:25 am
I like this photo. Nice result.
