Dust Spot Problem
Sat Oct 04, 2003 2:31 am
Hey all,
I'm looking for some help. I have at least 15 (!) dust spots on my pictures.
I've tried cleaning my CMOS with a speckgrabber but that only created more spots. I've also cleaned all my lenses.
Was wondering how you clean your CMOS' most effectively? What techniques should I use to get rid of those unwanted spots?
Tim
Unique
RE: Dust Spot Problem
Sat Oct 04, 2003 3:00 am
Bring your camera to Canon for cleaning, that's the only way to get rid of the spots!
JeffM
Sat Oct 04, 2003 3:08 am
Tim,
If you can see 15 spots, then there is most likely 45-60 on the sensor you can't see.
You can try blowing them out, but more then likely you will just blow them around to a new location. A wet swabbing with Eclipse fluid and a swab would be the next best thing to a professional cleaning.
Jeff
Jan Mogren
Sat Oct 04, 2003 4:16 am
I was terrified first time I cleaned my cmos but it really isn't that scary. I use something by Resolution called DiGiCLEAN and it works great.
Just be careful and follow the instructions.
Canon repair would take time and cost a lot more. If you change lenses alot you are bound to have dust spots frequently so might as well get used to doing it yourself. Anyway that's how I figured.
/JM
AeroPresentation - Airline DVD's filmed in High Definition
aagold
Sat Oct 04, 2003 4:29 am
I'm with Jeff, do it yourself with Eclipse fluid and either purchased swabs or ones that you've made yourself. I, too, was scared to death the first time I did it, but I've done it a few times since I got the materials and was successful each time. Just be careful and remember the sensor is a delicate item and treat it so.
Search this forum for this topic. There was a thread just a few weeks ago that gave really good instructions on how to get the required materials and how to proceed.
Art
JeffM
Sat Oct 04, 2003 4:36 am
http://www.pbase.com/copperhill/ccd_cleaning
That link is full of pictures describing the process. It is painless.
Jeff
Fly-K
Sat Oct 04, 2003 5:52 am
Very useful advice!
Konstantin
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been...
wietse
Sat Oct 04, 2003 6:29 am
Am I just lucky that I dont have any noticable spots (around F8) after over 7000 exposures on my D60? I hear everyone talking about dust, but I didnt notice any yet.. If I make an exposure @ F32, I see some small specks, but only about 5 of them in total.
Wietse
Wietse de Graaf
aagold
Sat Oct 04, 2003 12:38 pm
Wietse
I know we all talk about dust spots on the CCD, but I've really begun to doubt if it really is dust. I've actually come to believe it might be condensation formed from taking the camera in and out of air conditioned areas to hot humid shooting locations. One of the reasons I doubt it's dust is from using a bulb blower to try and clean it and it having no effect at all. I figure if it was dust the spots might at least change position a little, but they don't. The only thing that makes me think it might actually be dust is that the spots are generally quite small, however, I've had a couple of really good size ones also.
Unfortunately living where I do I don't see any alternative to exposing the camera to air conditioning and then hot/humid weather. It's a fact of life.
Art
Granite
Sat Oct 04, 2003 9:32 pm
Hi all
I must be very lucky as never really been plagued by dust spots on my D30.
The few that I did have were easily seen while viewing the sensor at a window and the Speckgrabber picked them up with no problems.
I've avoided brushes, blowers and swabs from the very start.
Gary Watt
redfox
Sat Oct 04, 2003 9:45 pm
Hi All
It could be the lens(s) I have a 28-200mm lens that had a small insect claim it as a home the very first time I used it!!. Can't see the squatter anymore but it must be there, along with much dust. I guess our application of photography calls for standing in dusty locations not to mention the bugs!
Stephen Fox
Mon Oct 06, 2003 5:50 pm
Hey guys,
thanks for the good advice. I've decided to reclean everything once again with my speckgrabber. If that doesn't do the trick then I'll order the fluids mentionned above. Hope I got rid of all the spots as I have a heck of a weekend coming up.
Thanks again,
Tim
KingWide
Mon Oct 06, 2003 8:05 pm
This probably doesn't apply to most of you but if you're a member of CPS [Canon Professional Services] then they do a free equipment clean/check as part of the service.
J
Jason Taperell - AirTeamImages
Granite
Mon Oct 06, 2003 8:48 pm
Hi Jason
Showoff  Wink/being sarcastic
Gary
Mon Oct 06, 2003 8:58 pm
How much does CPS cost per year? Any conditions or can anyone join?
Tim ('em trainee photographa)
cabbott
Tue Oct 07, 2003 1:15 am
Guys
Any ideas where i can lay my lands on a speckgrabber in Europe or the UK?
Thanks Colin
PUnmuth@VIE
Tue Oct 07, 2003 1:28 am
TZ
Tue Oct 07, 2003 1:53 am
These guys are VERY good:
http://www.crown-digital.co.uk/
Tamsin
TZ Aviation - Aeropuerto de los Banditos Team Images
Jan Mogren
Tue Oct 07, 2003 2:14 am
To have any use at all for the speckgrabber you gotta be able to see the blob on the sensor when you peek into the chamber.
Most dust spots are way smaller than that.
/JM
KingWide
Tue Oct 07, 2003 4:40 am
:o
CPS is free but you have to own a minimum amount of gear [something like two pro bodies and 3 L lenses] and be a 'professional'. The exact definition of 'professional' is a bit flexible and each country seems to do it differently. Basically it seemed to come down, for me at least, to do you regularly shoot on commission and, therefore, need the backup that CPS provides? In my case, my motorsports stuff, was good enough for membership.
It seems to me that many of us, in gear terms, qualify for membership and it may be worth pursuing to see how far they will stretch the definition of 'professional'.
J
Granite
Tue Oct 07, 2003 5:56 am
Hi all
Colin, like Tamsin, I got my one from Crown Photo in the UK.
I opted for the 'deluxe' screwdriver handle version  Smile/happy/getting dizzy
Gary
Rotate
Tue Oct 07, 2003 9:09 pm
aloha,
Nikon cleaned my CCD allready three times this year,without sending my a bill .... , NIKON is just quality gear and service  Smile/happy/getting dizzy
robin
ABC
wietse
Tue Oct 07, 2003 9:33 pm
But it did require 3 cleanings this year allready right? So much for the quality gear  Big grin
My canon hasnt had a dustproblem at all since feb.
Wietse  Smile
Wietse de Graaf
glennstewart
Fri Oct 10, 2003 12:17 am
Canon's apparently suffer far lass CCD dust than the Nikons.
My 10D requires a puff of air once a month for complete removal of dust spots. Only about 1% of my originals seem to have dust spots in them... and only if I look hard.
Glenn
Respected users.... If my replies are useful, then by all means...
