747 4-ever
Help Needed On A Few Rejections.
Sat Oct 11, 2003 10:20 pm
Hello, I'd need some help on these two rejections.
http://airliners.net/procphotos/rejphoto.main?filename=Spanair_MD-80_EC-FXY_030604.jpg
Rejected for baddouble. The other photo is this
Photo © Daniel & Robert Fall
Are these two shots really that similar?
Also, this photo (http://airliners.net/procphotos/rejphoto.main?filename=Novair_A320_CS-TNE_1.jpg)got rejected for badmotivbadinfobaddark, The darkness is because there were a lot of clouds that day and the plane got hit by a few sun rays. I can't see what the badinfo is, any suggestions?
Best Regards,
Robert Fall
wietse
RE: Help Needed On A Few Rejections.
Sat Oct 11, 2003 10:21 pm
Its a -320-212. A simple search using the reg could have revealed that for you. I like the pic btw, nice atmosphere.
Wietse
Wietse de Graaf
747 4-ever
Sat Oct 11, 2003 10:26 pm
Thanks for the comment, but as I wasn't 100% sure, it wrote 320-... Because if you do a search for the reg, you get some saying -212, some -214 and som -... so I wanted to be on the safe side. Do you think it has a chance if I fill in the correct info?
Robert
codeshare
Sat Oct 11, 2003 11:15 pm
The're kind of similar, but they also show the same a/c.
As for the A320, the baddark is probably for the dark engine, the bottom of the wings and the fuselage, therefore - baddark.
Try to fix this with 'Curves' in Photoshop, or whatever program you're using.
Either the angle is bad or this 'hill' or piece of tarmac is in the way of the main gear - it's not fully visible, hence - badmotiv.
Do you have other shots of that A320? Maybe the gear is fully visible there.
How much A is there is Airliners Net ? 0 or nothing ?
Users browsing this forum: HarryLi and 9 guests
