COPA737
Canon 300D Lens
Sun Oct 26, 2003 9:10 am
Hi,
I brought my Canon 300D the past friday. I tried with a Canon 75-300 4.5-5.6 Lens, but the photos came out really dark. I asked to some people and they told me that it could be the lens I was using.
So thats why I'm asking what lens do you guys use on your Canon 10D or 300D. And what settings are the best to get clear shots!
Felipe
Panamá Crece y Copa Airlines crece con Panamá!
MIA777
RE: Canon 300D Lens
Sun Oct 26, 2003 9:13 am
Your photos probably came out dark because of crappy weather. The lens (I own it) really does suck when there isn't a lot of sun (or at least that is my opinion). What setting is it on when you are shooting? Tell more about the weather conditions and the settings...
MIA777
yegpix
RE: Canon 300D Lens
Sun Oct 26, 2003 10:37 am
Post an unedited sample if you can and we will see what you mean.
Kevin
COPA737
RE: Canon 300D Lens
Mon Oct 27, 2003 12:49 am
Hi,
These are some examples:
http://www.geocities.com/copa737800/hp1377.jpg
http://www.geocities.com/copa737800/airesdash8.jpg
Please paste the links on a new browser.
Best Regards,
Felipe
COPA737
RE: Canon 300D Lens
Mon Oct 27, 2003 1:30 am
mirage
RE: Canon 300D Lens
Mon Oct 27, 2003 1:39 am
Don't worry, that's normal, now you have to work the photos on Photoshop. DSLR original pictures ALWAYS need to be edited to extract the maximum quality.
Nevertheless, on the 737 photo the light conditions were not good, the sun seems to be in front of you.
But, it's not a lens problem.
Luis
yegpix
RE: Canon 300D Lens
Mon Oct 27, 2003 6:53 am
I agree. Adjust the levels in photoshop and they will look alright.
serge
RE: Canon 300D Lens
Mon Oct 27, 2003 7:17 am
Hi Felipe,
Might want to try calibrating your monitor again as well:
http://www.airliners.net/AirMonitor.zip
Serge
BTW, still think I hacked your computer? LMAO, that was the funniest (and most stupid) shit I've ever heard!  Sleepy  Nuts
COPA737
RE: Canon 300D Lens
Mon Oct 27, 2003 8:14 am
Serge,
hahaha, Later I knew it wasn't you!
Luis and Kevin what lenses you guys use?
Thanks for your opinions..
mirage
RE: Canon 300D Lens
Mon Oct 27, 2003 8:34 am
Felipe, until September I was using a Canon 75-300 IS with a Canon D60, my results were just your two examples above. The lens is fine, no problem, it's very important to work the photo on Photoshop.
MIA777
RE: Canon 300D Lens
Mon Oct 27, 2003 9:05 am
Whoa...that is not as dark as I thought they would be (try shooting in low light!). Fix the levels in Photoshop/unsharp mask, your photo is good.
MIA777
yegpix
RE: Canon 300D Lens
Mon Oct 27, 2003 11:16 am
Felipe, I use the same Canon 75-300 USM as you, it's not too bad for its low price. I also recommend using the monitor calibration software. Most monitors need to be adjusted from the factory settings. I also ran your pics through photoshop and they were easily improved.
Kevin
COPA737
RE: Canon 300D Lens
Mon Oct 27, 2003 12:21 pm
Thanks a lot both of you for your help!!
I will use the photoshop to fix the photos.
Felipe
triple7300
RE: Canon 300D Lens
Tue Oct 28, 2003 5:58 pm
Hallo Felipe,
photographing with a D60 since over 1 year I first used the same lens like you.
I was not very satisfied because it was vigneting (dark edges) at 300mm.
Now I use a 100-400 IS L USM (a really not cheap lens) but the results are quite good.A alternate to this lens will be the 75-300 IS which a friend of mine is using.It produces a good quality.But reworking with a Photo editing program (i.e.Photoshop) is always necessary.
Wishes
Andy
