747 4-ever
Help Me Find The "badinfo"
Wed Nov 12, 2003 12:47 am
Hey,
This rejection is really puzzling me, it got rejected for badinfo, but I can't really see what's wrong! Any ideas would be appreciated!
http://airliners.net/procphotos/rejphoto.main?filename=SAA_C172R_SE-.jpg
Robert
Rotate
RE: Help Me Find The "badinfo"
Wed Nov 12, 2003 12:50 am
aloha,
i am guessing, you should not name the company,it should be : UNTITLED
but,dont ask me why ....
cheerio robin
ABC
747 4-ever
Wed Nov 12, 2003 12:56 am
But it belongs to an aviation academy and it has "Scandinavian Aviation Academy" titles.. Shall it still be listed as untitled?
Rotate
Wed Nov 12, 2003 1:14 am
yep,thats correct, even , if it belongs to "scandinavian avation academy" it should be marked as untitled .... , but lets wait,what other guys tell you ....
robin
ABC
cicadajet
Wed Nov 12, 2003 1:28 am
747 4-ever
If it has "Scandinavian Aviation Academy" titles, it should indeed go in as with that exact title. (but you might utilize that "note for screeners" field in the upload to let them know it has titles.)
Were you not able to get a registration as well?
Tom
747 4-ever
Wed Nov 12, 2003 3:42 am
Thanks for the comments guys!
Tom, SAA has 8 C172R, and unfortunately I don't have the exact reg for this one..
Shall I appeal the shot? With a note that it does have titles?
Robert
[Edited 2003-11-11 19:43:22]
cicadajet
Wed Nov 12, 2003 12:49 pm
Robert,
I'd probably re-upload it, rather than appeal, with a note to screeners that it had been rejected for BadInfo last time...note the aircraft has titles and you didn't get the reg # (that could be a problem - not sure). Be sure to check "private" and "single engine prop" on 2nd page..etc.
Good luck,
Tom
Invader
Wed Nov 12, 2003 5:29 pm
When it has titles they have to be listed, so then Scandinavian Aviation Academy would be correct. I'm not involved in the screening, but I think the problem is that no registration is supplied. A Cessna 172 is quite a common aircraft, and then an anonymous example doesn't add much to the database. We have an editor assigned to the Cessna 172, and by having the registration he can verify the correct version and add the cn, which gives more value to the picture. But if you don't know the registration and you still want to upload it, it should at least be listed as SE-***.
Peter Vercruijsse
Chief Database Editor
