Patrick_L
What Do You Think Of My First Shot?
Tue Dec 30, 2003 10:53 am
Hey everyone..  Big grin Big grin
http://airliners.net/procphotos/rejphoto.main?filename=GRZ25122003OELTM.jpg
I want to join the club of "spotters" now and this is one result of my first rounds of pix which I tried to upload. Got rejected for "overall too dark"!  Sad
Nevertheless, what do you think? How can I fix it up - or is it worthless to spend time on this picture?
Thank you very much for your input!
Happy Spotting,
Patrick
goboeing
RE: What Do You Think Of My First Shot?
Tue Dec 30, 2003 11:02 am
I think it's a good picture. Maybe if the sun had been behind you it would have turned out better.
Nick
vafi88
Tue Dec 30, 2003 11:54 am
Go to photoshop and play with the curves a bit, definitely a good shot.
I'd like to elect a president that has a Higher IQ than a retarted ant.
SlamClick
Tue Dec 30, 2003 12:46 pm
I agree, I like the shot. I think I would make a copy and try something in Photoshop. Think I'd crop a bit, maybe even cut off the mainwheel because you can't see all of it. Keeping my shape, I think mostly I'd cut off a bit of the very bright sky and then see if that would permit me to bring up the brightness of the fuselage sides without burning out the remaining sky completely. Edit the "curve" probably.
I like the light and shadow inside the cockpit and the flash of prop behind them. If they never accept it, it would still look good on your wall.
vafi88
Tue Dec 30, 2003 2:23 pm
I disagree, cutting off the nose gear might leave you with a nice bad motive rejection, just play around with the curves.
JeffM
Tue Dec 30, 2003 2:25 pm
Just "dodge" the mid-tones/highlites a little on the fuselage the exposure behind the plane is good.
2912n
Tue Dec 30, 2003 2:27 pm
Sometimes location just dictates what to shoot, but try to avoid backlit subjects. It just works against you unless you really know what you are doing and/or are trying for a certain effect.
You might be able to save this by playing levels as noted above. I think you could use a bit of USM, appears a bit soft.
The light playing on the prop is nice and the photo has potential. Half the battle can be in your post processing so keep at it!
TOny
An-225
Tue Dec 30, 2003 3:46 pm
The main problem to me, seems that there's a lot of empty space in this picture - crop it a little tighter, a little USM and curves should do the job.
Good luck,
Alex.
Money does not bring you happiness. But it's better to cry in your own private limo than on a cold bus stop.
rotor1
Tue Dec 30, 2003 6:57 pm
I really like that photo... unfortunately, it's "offbeat" and pretty "artsy", along with some imperfect lighting, which throws it off of the ALN quality curve. Had the lighting been on your side, you still might have gotten a "badmotiv", but in any case, I think you're definately on the right track and it's only a matter of time before you get some photos on the site.
At least you're not bummed about a reject! That's better than SOME of us (why are you all looking at me?)...
Mike
The best aviation photo I've ever taken was rejected by Airliners.net
Patrick_L
Tue Dec 30, 2003 10:26 pm
Hello again!
Thank you all for your input. I will just play around more with post processing in PS. Can't wait to get some new pix..Unfortunately bad weather at the moment.
Thanks again and regards
Patrick
manzoori
Wed Dec 31, 2003 12:29 am
Hi Patrick,
A little tweaking of levels, with a touch more USM and this is what I got:
Cheers!
Rez
 Big thumbs up
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
Patrick_L
Wed Dec 31, 2003 4:28 am
Hello again everyone...
I tried to edit the image and lighten it up a little - thanks Manzoori for posting your example.
I use Paint Shop Pro - could somebody explain the USM function  Big grin !?
What do you think? Worth re-uploading?
Another reason why the picture seems dark is probably because the airplane (except for the nose cover) was very dirty...
Click : http://www.gibs.at/airbus/sample.htm
Patrick
