Just_Plane_Mad
Motion Blur Question
Thu Jan 15, 2004 10:32 pm
Hi guys just not long bought me a Canon Eos 300D DSLR was wondering and am interested in motion blur and how to get good motion blur at that , is anyone able to assist me with some tips at all ?
thanks in advance,
Will Mallinson
UTA_flyinghigh
RE: Motion Blur Question
Thu Jan 15, 2004 10:56 pm
Just shake the camera a little Big grin
UTA
Fly to live, live to fly - Air France/KLM Flying Blue Platinum, BMI Diamond Club Gold, Emirates Skywards
wietse
Thu Jan 15, 2004 11:05 pm
Photo © Wietse de Graaf
Like these? Just set the shutter to somewhere near 1/25th of a second and follow the subject with a nice smooth pan. Should come out nice with a bit of practice. For best results do this at dawn/dusk. That gives the best images.
Wietse
Wietse de Graaf
LGW
Thu Jan 15, 2004 11:06 pm
As I don't have to humor of William  Nuts I think I shall answer a little differently.
Basically when panning an aircraft for example coming into land, set the camera to Tv mode and lower the shutter speed to as low as you think you can physically coupe with and still get a good image.
Then pan the aircraft well, hold the camera very steady, remembering to contunie to pan after the shot for a bit to make sure you dont mees the shot up and then view the resuls on your LCD.
Its a little trial and error to start with but its not too hard once you get better at it.
Ben Pritchard
ckw
Thu Jan 15, 2004 11:23 pm
As above, but just to emphasise that the secret is a smooth motion before, during and after shutter release. Most people seem to instinctively freeze the camera when they press the shutter, or jerk the camera up/down a little. If you've ever played golf, its a little similar - you need to pan through the shutter release like you're supposed to swing through the golf ball.
Colin
Colin K. Work, Pixstel
IL76
Thu Jan 15, 2004 11:31 pm
Photo © Eduard Brantjes
Make sure the plane it not coming at you as the angle of the plane changes while the shutter is open. The nose or tail will go blurry, as they have a different relative speed towards the camera. Side-on works the best, as the angle of the plane hardly changes during the shot. Keep the motion fluent as Colin said and use a slow shutterspeed (<1/125th).
[Edited 2004-01-15 15:33:16]
[Edited 2004-01-15 15:47:43]
rotor1
Fri Jan 16, 2004 5:40 pm
They all make it sound so easy... and therein forget the most important step...
Set camera to drive mode. Hold down the shutter button and take lots and lots and lots and lots of pictures. If you take at least 1,000 photos, you should have 1-2 good ones  Big grin
I've found good pan-action hovers around 1/125 to 1/80th. Leave the lens as wide (backed out) as you can and still get the shot, which helps decrease blur from camera shake.
The best I've done has been 1/80th at about 400mm... it was a miracle the shot came out as well as it did:
Photo © Mike "Rotor" Nowak
My goal is to eventually get a 1/4sec shot with the a/c perfectly sharp. One day...
Mike
The best aviation photo I've ever taken was rejected by Airliners.net
ckw
Fri Jan 16, 2004 7:14 pm
Something I've never done - an article I read a long time ago prejudiced me (probably irrationally  Smile) against motor drives. It put forward the arguement that even if you shot 10 frames/sec at, say, 1/100th, you still only have a 1 in 10 chance of catching the critical moment. For example, on an aircraft landing, relying on continous drive makes capturing the exact moment those tires touch the tarmac pretty remote.
Of course most aircraft shots are not quite so time critical, and Mike's advice makes perfect sense - I sometimes wonder after the fact why I didn't keep my finger on the shutter. Old habits die hard.
Colin
airportugal
Fri Jan 16, 2004 7:26 pm
This is my first successful attempt at doing some motion blur shots.
Photo © Luis Gonçalves
I set the speed to 1/80th and held the camera as steady as possible. I had to shoot 6 frames before getting a decent shot. And yes, the camera used was the EOS300D.
Luis G
Just_Plane_Mad
Fri Jan 16, 2004 8:44 pm
WOW ! thanks so much guys ! i'll b sure to give it a go and keep on practicing  Smile
Will Mallinson
Kempa
Fri Jan 16, 2004 11:53 pm
Do not use the camera LCD display. Use the eye viewer, and follow the plane with your head and your body. Keep the camera on drive and the button pressed. Do not use autofocus or any other automatic function, manually set the focus to the distance you want to shoot. You don't want your camera to delay your shots because it is metering the shots before the shutter starts operating.
ckw
Sat Jan 17, 2004 12:36 am
Kempa, you've probably managed to highlight in a single paragraph the key differences between shooting with a DSLR and a digicam.
In the case of the 300D as used by Will (and other DSLRs), you don't have the option of using an LCD to compose and shoot - the point of the SLR design being to look through the lens itself via the viewfinder. As far as metering goes, this is performed continously and instantaneously right up to the moment the shutter opens (unless of course you choose to lock the exposure) - this can be a real plus in continuous shooting, particularly with intermittent sun.
Again with AF - as far as I know, all DSLRs have a servo mode which allows moving objects to be continuously tracked by the AF system right up to the point of the shutter opening.
Certainly your comments are useful and valid for digicams - but do perhaps illustrate what DSLR users are paying for  Smile
Colin
fallingeese
Sat Jan 17, 2004 12:56 am
I have had some success with it, and love to do it. I'm a fan of the hold down and prey method.
Photo © Mark McWhirter
Mark McWhirter...Contrails Photography
MIA777
Sat Jan 17, 2004 4:57 am
Something I've never done - an article I read a long time ago prejudiced me (probably irrationally ) against motor drives. It put forward the arguement that even if you shot 10 frames/sec at, say, 1/100th, you still only have a 1 in 10 chance of catching the critical moment. For example, on an aircraft landing, relying on continous drive makes capturing the exact moment those tires touch the tarmac pretty remote.
Funny you mention that. I read the same thing in a book yesterday and it basically said that many times the real action you want capture is in between each exposure and its better to stay away from continious mode. (I know that's exactly what you are saying). However wouldn't "pressing" cause slight camera shake which would potentially ruin the photo?
MIA777
IL76
Sat Jan 17, 2004 5:03 am
Moving your finger 0.5mm won't create very much shaking. Not more shaking than from an SLR mirror going up and down like crazy when keeping it pressed during the shoot...
[Edited 2004-01-16 21:08:37]
wietse
Sat Jan 17, 2004 5:30 am
I dont think he means the actual click, more the force your finger has on the shutter. When pushing it, you slightly tilt the body, so either be very carefull with your shutter, or fire a sequence to prevent this from happening.
Wietse
Wietse de Graaf
IL76
Sat Jan 17, 2004 5:43 am
Ok... I see. I haven't experienced that though. The shutter requires very little force and moving only the last 2 joints of the index finger... But, true, it is a point of attention with panning shots: Keep cool and click gently.  Smile
[Edited 2004-01-16 21:43:48]
maiznblu_757
Sat Jan 17, 2004 8:13 am
SHAMELESS PLUG ALERT!  Big thumbs up
I messed with the aperture for this shot. I cannot remember the settings right off, it was taken with my Minolta 700SI with Fuji Sensia film scanned with the Dimage Dual Scan II. I am going to work on a better scan, I have new software.. Anyways, just experiment.
Photo © Chad Thomas
Sat Jan 17, 2004 8:28 am
Hey,
Haven't tried many yet, mainly cuz I like to nail a plane properly.
Here's one picture I have up:
Photo © Timothy Feise
Technical details: f/7.1, 1/40s, 189mm, iso 100
Tim
PW100
Sat Jan 17, 2004 8:31 am
Have tried some myself, with mixed results. Not yet up to par with A.net standards.
How about these for motion blur . . . . . did they forget to close the shutter???
Photo © YOSHIAKI HOSHINA
Photo © Matsushita Masashi - aozora karugamotai -
Harm
PUnmuth@VIE
Sat Jan 17, 2004 6:25 pm
Just 2 of my successful attempts:
Photo © Peter Unmuth - VAP
And one of the ones with a very low shutter speed. 1/40 and the camera on a monopod. this was the sharpest one out of three shots. It was number 2.
Peter
[Edited 2004-01-17 10:37:36]
[Edited 2004-01-17 10:37:57]
Marco_Polo
Sat Jan 17, 2004 7:31 pm
Will:
Clovis and Paul Paulsen from LAX they both seems to be pro at motion blur images. Here are some of their sample works. You might want to shoot e-mail over their way just to get some detail from them. I believe they use TV mode (Shutter Piority Mode) and setting it between 1/60th to 1/125th of sec. Aperature setting are automatically calculate and set by the camera.
Photo © Reve
Photo © Reve
Photo © Reve
Photo © Paul Paulsen
Cheers - Jay
Just_Plane_Mad
Sun Jan 18, 2004 2:04 am
Thankyou guys SO much for all your help with my question , i gues i'll b referring to your suggestions quite a lot while i learn !
once again thankyou very much , much aprecciated !
Will Mallinson  Smile
Granite
Sun Jan 18, 2004 6:00 am
Hi all
Photo © Gary Watt
I got the above image by accident  Wink/being sarcastic
Gary Watt
ExitRow
Sun Jan 18, 2004 2:43 pm
Click for bigger version
A 3,000 lbs. Gitzo tripod helps a great deal too...  Big thumbs up
William
paulinbna
Sun Jan 18, 2004 3:20 pm
In my experience with this like some else said before the best seem to come out better when you shoot from the side of the aircraft. Like this:
Photo © Paul Robbins
The second one was taken at 1/30 sec. and yes it was coming towards me. I took about 8 pictures (not on burst) of the second one this is the only one that came out.
But the great thing with a DSLR is try try try again and you will eventually get it.
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
andyhunt
Crew
Mon Jan 19, 2004 12:56 am
Sorry, had to plug this one Big grin
Photo © Andrew Hunt
Was over the moon when I processed it.......!
Andrew
Full frame always beats post processing
Mon Jan 19, 2004 1:37 am
Andy,
Great picture!
Forgot about this one:
Tim
aviatortj
Mon Jan 19, 2004 8:03 pm
This is one of my first attempts at motion blur. Beware of shameless plugging ahead:
Photo © TJ OKeefe
I found it was easier to just go with faster shutter speeds and stop the motion. You only get so many opportunities  Wink/being sarcastic.
__TJ__
