maiznblu_757
What Would You Use This Lens For?
Tue Jan 20, 2004 11:51 am
I think I would use it as a Billy Stick...
Quantaray - 600-1000mm Zoom Lens (T-mt.) $349.00
AND NO, I AM NOT GOING TO BUY THIS...  Big grin
vafi88
RE: What Would You Use This Lens For?
Tue Jan 20, 2004 11:54 am
Possibly contrails??
Or! You can catch airplanes on finals (I can just see a quote like: Airbus A340 about 3 minutes before landing at ___ airport)  Big thumbs up
If I had the money (and the camera), I'd buy it!
I'd like to elect a president that has a Higher IQ than a retarted ant.
maiznblu_757
Tue Jan 20, 2004 12:06 pm
I am sure the quality is a bit sub-standard.
PilotHighFlyer
Tue Jan 20, 2004 2:13 pm
Paper Weight
Door Stop
Weight lifting (Prolly pretty light tho)
Dog Toy
Increasing ones ego at the airport by having the longest lens?
Just a few ideas....
Robert
JeffM
Tue Jan 20, 2004 2:37 pm
That is a bird watchers lens.
v/r
Jeff
gocaps16
Tue Jan 20, 2004 4:18 pm
no no no, Jeff.
That is a peeping tom's lense. :-P
It also requires a T- mount.
Kevin
cfalk
RE: Clark Supported U.S. Policy & Intelligence On
Tue Jan 20, 2004 8:53 pm
When shooting airplanes beyond 600mm or so, unless you have an extremely clear day, you will get different haze effects, either heat, or simply smog or vapor. Also, if you want to shoot good quality shots, 100 ASA might not be nearly sensitive enough.
Keep this lens for bird-watching.
Charles
Vulindlela
Tue Jan 20, 2004 10:09 pm
I have the 650-1300mm lens that looks just like that. I got it (knowing it would be poor quality) just to mess around with, and for $200 on ebay. My friend took it to SFO and had some impressive shots with it. They won't get accepted here for sharpness, but some of them were very good. The build quality of the lens is bad-it is just a tube sliding over another tube to zoom, and there is no aperture adjustment or lens contacts (probably constant f8). But, I still think it is fun to use sometimes.
-Kevin
"If you take everything I've accomplished in my entire life and condense it down into 1 day, it looks decent!"
