patroni
Canon EF 300mm F/4.0L Is?
Mon Feb 16, 2004 4:27 am
Hello,
I was just wondering if anyone here has experience with the Canon EF 300mm f/4.0L IS in aviation photography? I recently saw some detail shots of taxiing aircraft which looked razor-sharp, but how is the result with faster moving objects?
Also, does the image stabilizer still work when panning or is it an earlier IS which is mainly made for standing objects?
At the moment I have the Canon 70-200/F4 L USM and am very happy with it, have also thought of buying the 100-400/3.5-5.6 L IS USM, but maybe a 300mm would be a better choice, even if it does not offer the flexibility of a zoom?
Sorry if this has already been posted, but the search function didn't bring any result.
Tom
chris78cpr
RE: Canon EF 300mm F/4.0L Is?
Mon Feb 16, 2004 6:22 am
I am in exactly the same boat as you Tom, but after testing both lenses i have chosen on the 100-400! Although it is not as fast or as sharp, it is much more flexible and alot better suited to aviation photography!!! The 100-400 can produce some amazing images, just have a look at Ryan Hemmings for proof!!!
If you get this lens you will not be dissapointed!!!
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
ckw
Mon Feb 16, 2004 8:01 am
This is pretty much my "standard" lens for aviation, and it can be used with convertors for greater reach (though you will loose AF).
IS is 2 mode and works well for panning.
Colin
Colin K. Work, Pixstel
chris78cpr
Mon Feb 16, 2004 8:20 am
Colin,
Do you really find a fixed focus lens that good for aviation photography at UK airports???
Chris
TS
Mon Feb 16, 2004 8:46 am
Hi Colin,
Do you lose the AF even with only one teleconverter attached?
Thomas
Even a broken clock is right twice a day.
Staffan
Mon Feb 16, 2004 8:57 am
You'll have AF with the 1.4, but not with the 2X.
Staffan
fireguy274
Mon Feb 16, 2004 9:17 am
You loose the AF with the 1.4 Staffan I have the 100-400L IS USM and the 1.4. I do loose the AF with it. This is a great lens Tom and I can highly suggest it. I have both the 100-400 and the 70-200 2.8L IS USM. I like the 70-200 a little better but you cant beat the reach with the 100-400. I think the lens is more versatile than the 300 fixed and you will be happier with it...Artie.
Staffan
Mon Feb 16, 2004 9:29 am
That depends on the lens. The 300 is f/4 and will be f/5.6 with the 1.4. The 100-400 is f/5.6 and will be f/8 with the 1.4. Only EOS 1 & 3 have AF over f/5.6.
Staffan
ckw
Mon Feb 16, 2004 9:36 am
AF - 2x gives an effective aperture of f8 - AF will work only on top end Canon bodies (EOS 1,3 1D 1Ds). AF will work with the 1.4 (effective aperture is 5.6 when used with the 300).
Chris - fact is I use 2 bodies, and usually have the 70-200 on one body, the 300 (usually with a convertor) on the other. If I was using 1 body, I probably would have kept my 100-400, though in practice I don't find fixed focal lengths particularly problematic.
As with all things its a tradeoff - convenience against quality, though don't overlook the fact that with convertors, the 300 can give you more reach than the 100-400
Colin
chris78cpr
Mon Feb 16, 2004 9:54 am
I guess i'll just have to get the new 1dmkII!!! LOL I'm sure i can live with it!!! I think the 1DmkII with a 100-400 and the 10D with a 300mm w/1.4xII attached!!!
Chris
fireguy274
Mon Feb 16, 2004 11:09 pm
I have the Canon 10D and the 1.4X extender. The 100-400L USM IS will not work on auto focus with the 1.4X extender. If you read the manual for the extender it tells you this and I have tried it. Stay safe....Artie
lyzzard
Mon Feb 16, 2004 11:29 pm
The 100-400L AF with a converter will not work with anything above f/5.6. So at 400mm, it becomes something like an f/11 as the 2x will add 2 stops. I recently purchased a Canon 2x MkII extender and was quite disappointed with the overall results. I think it will be best suited to something like a 70-200 f/2.8 where AF is still available. You're definitely in tripod country if u add that converter on a 100-400L.
I did attempt a couple of shots on moving subjects. Imagine trying to focus, zoom in/out with a setup that long and heavy. Results improved greatly with the cam on a tripod.
patroni
Tue Feb 17, 2004 1:04 am
Thanks guys for the interesting discussion. I only have one body (speaking of my camera), so probably the 100-400 is the more practical solution....
Even though the fixed length 300mm sounds tempting, especially with the 2-mode IS.... Ah well, I still have some time before I get the right... mood ($$$) to buy a third lense, and next month I have the opportunity to try the 100-400. I am still a bit sceptical whether I would like the push/pull zoom though.
Tom
rotor1
Tue Feb 17, 2004 7:26 am
IIRC, the 100-400L has 2-mode IS as well. Mode 2 worked very well for me when I tried out 2912n's lens:
Photo © Mike "Rotor" Nowak
Try that with a single mode IS lens!
-Mike
The best aviation photo I've ever taken was rejected by Airliners.net
patroni
Sat Feb 21, 2004 9:39 pm
As a first step I have now ordered the Canon 1.4 EF extender to go with my 70-200/F4 L lens. Should give me 280mm (440mm eff.) at F5.6. And the price of 300EUR (US import, incl. customs duty, shipping, VAT) vs 415EUR (Germany) was too tempting....
Regarding the difference between the 300/F4 and the 100-400/4.5-5.6, I was surprised to read in a test that the fixed length 300 with IS actually scored not as good as the 100-400.... the old 300/F4 without IS got better results.
These tests can be found here : http://www.photodo.com/nav/prodindex.html
So I think the next addition might be the 100-400...
Tom
ckw
Sat Feb 21, 2004 10:30 pm
I've seen many photodo results queried in the past - and none more so than this one. Having had both lenses, I have no hesitation in saying that the 300 is better than the 100-400 at any aperture - hell, the 300 & 1.4 is better than the 100-400 at 400mm.
Not just my view - I've seen this result queried many times in various forums.
Colin
chris78cpr
Sat Feb 21, 2004 10:36 pm
Damn you Colin, just after i was all set on the 100-400 you throw that into the works!!! I dont know what to do now!!!! Grrr!!!
Chris
patroni
Mon Feb 23, 2004 7:03 am
Argh.. Colin, now it was all just so nicely set up (Zoom = greater flexibility + better test results = BUY!!) and then you just let this nice bubble burst  Big grin
I will use the next weeks to play with my 1.4 extender and test the usual locations at my home airport to see whether a fixed length 300 would be practical there or whether it would guarantee to get the windsocks and lamp posts in the way all the time. Next month I'll test the 100-400 myself and after that I will - hopefully - be much wiser (and probably much poorer....) than now.
Thanks for your great help!
Tom
