roots
USM Application... Which Method Is Better?
Fri Feb 20, 2004 3:23 am
I'm wondering what's the consensus here between these 2 methods:
1) Use a relatively small to moderate settings (50%/0.5 pixel/0 threshold) and apply it in multiple passes
2) Use a relatively large settings (100-150%/0.5 pixel/0 threshold) and apply it only once
What's the advantage / disadvantage of each? Is one a clear winner over the other?
I have tried both methods but personally most of the time I couldn't tell the difference.
Jkw777
RE: USM Application... Which Method Is Better?
Fri Feb 20, 2004 3:41 am
To be honest, I don't see the difference between the two. But the idea of applying it in small measures just takes that risk of producing jaggies. Personally I like to mix it up, it all depends how I feel to be honest.
Justin  Big thumbs up
jkw6210@btopenworld.com or +447751242989
futterman
Fri Feb 20, 2004 3:50 am
"How do you feel today, Justin?"
"Oh, a little pissed"
"Why don't you go sharpen some photos?"  Big thumbs up
Roots: I use USM usually in one shot, but sometimes apply it twice or three times. The values are in the range of 100/0.3/6. Justin might actually be on to something in regards to it being a 'mood' thing...
What the FUTT?
Jkw777
Fri Feb 20, 2004 4:02 am
Haha! But it's a lovely UK saying I'm afraid! You suck Futterman!
Go home  Big thumbs up
Justin  Big grin
futterman
Fri Feb 20, 2004 4:50 am
You suck Futterman!
I know  Sad...time to go open Photoshop.  Laugh out loud Nuts
What the FUTT?
Jkw777
Fri Feb 20, 2004 5:04 am
I know ...time to go open Photoshop.
Heheh  Big thumbs up Ok let me rephrase what I said.....
To be honest, I don't see the difference between the two. But the idea of applying it in small measures just takes that risk of producing jaggies. Personally I like to mix it up.
Justin  Smile/happy/getting dizzy
wietse
Fri Feb 20, 2004 5:31 am
Always this for me
50%
.3
0
and applied 2-3 times. With L glass and a good DSLR you really dont need much sharpening. It all depends on your type of camera.
Wietse
Wietse de Graaf
Staffan
Fri Feb 20, 2004 5:34 am
I shoot slides and they need some sharpening. Usually between .2 and .4 and anything from 80%-300%.
Staffan
IL76
Fri Feb 20, 2004 5:44 am
I don't use USM... Big grin
eddl
Fri Feb 20, 2004 5:54 am
200% / 0.3 / 0 works for me ... (applied AFTER resizing).
EDDL
[Edited 2004-02-19 21:56:35]
TS
Fri Feb 20, 2004 6:09 am
I can second that. It also depends on the how much you zoomed (100mm barely any sharpening, 400mm much more sharpening) & the cropping you have done to the pic (no crop—less sharpening). For uncomplicated photos I often use the auto-sharpening, for more difficult cases I usually try USM, sometimes also combined. I also tried this gradual sharpening but couldn't find any advantages.
Thomas
Even a broken clock is right twice a day.
fuairliner
Sat Feb 21, 2004 12:36 am
I use two steps after resizing my slide scans (from around 3000 pixels to 1024 pixels wide): 500%/0.2/5 and 300%/0.2/0.
Explaination: By using 0.2 (instead of 0.3 or higher) small details are sharpened better, but it is not as strong. Therefore I need two passes. The 5 in the first pass is to reduce the grain, I guess this is not necessary with a digital SLR output.
Frank Unterspann - Hamburg, Germany
andrewuber
Sat Feb 21, 2004 9:51 am
I have a dumb question. I use Paint Shop Pro, and it has an unsharp mask as well, but the setting are different. In PSP, the format for the USM filter is:
Radius (0-100); Strength (1-500); and Clipping (0-100). All numbers are whole, no decimal is available.
Can anyone please tell me what settings should be used to sharpen a photo without adding jaggies? I understand it will vary slightly by image, but can someone give me a starting point?
DREW
I'd rather shoot BAD_MOTIVE
Users browsing this forum: No registered users and 9 guests
