Bruce
I Do Not Understand This
Fri Feb 27, 2004 2:21 am
I have had decent results lately on uploads and then I went to a place where I could shoot upclose and what happens? 22 out of 22 rejected! Badscan was the most common reason. And this email for 18 of the 22 did not have the "screener in training" disclaimer so I assume it is not an issue with a new screener learning the ropes. AND, I think they were all rejected on first screening!! How are these "badscans"??? Have the standards been raised again? Would uploading these at smaller size like 1200x800 help? Can someone please comment here? Something just does not seem right. This is extremely unusual.
http://airliners.net/procphotos/rejphoto.main?filename=N2FE_8717.jpg
http://airliners.net/procphotos/rejphoto.main?filename=N327NB_8708.jpg
http://airliners.net/procphotos/rejphoto.main?filename=N8839E_8704.jpg
the dots in the sky are birds....
http://airliners.net/procphotos/rejphoto.main?filename=N27523_8709.jpg
http://airliners.net/procphotos/rejphoto.main?filename=N8920E_8710.jpg
http://airliners.net/procphotos/rejphoto.main?filename=N8505Q_8719.jpg
http://airliners.net/procphotos/rejphoto.main?filename=N372FE_8732.jpg
the fence does not cover any portion of the plane
http://airliners.net/procphotos/rejphoto.main?filename=N311US_8712.jpg
here is a badcentered....is it the dead space on the right??? Geez....that is small compared to the left...i dont get it
bruce
Karlok
RE: I Do Not Understand This
Fri Feb 27, 2004 2:39 am
some photo's seems a little soft to me. And for the dots, tell the screeners that the dots are bird are to play safe and clone the birds away.
The last Northwest, badcentered? Yes, the dead space on the right is bigger than on the left side. 100% more, if you ask me.
Also the photo's are blueish.
Compare: (Click to enlarge)
[Edited 2004-02-26 18:41:16]
[Edited 2004-02-26 18:41:39]
Bruce
Fri Feb 27, 2004 4:18 am
well, now how did you get rid of that blue???? My original was worse than the rejected one; I had fixed it as I normally do but yours looks much better! do you use photoshop? did you just reduce the blue channel or ???
Karlok
Fri Feb 27, 2004 4:29 am
Yes, I use photoshop. Change the levels in photoshop or an another photo editing software.
JeffM
Fri Feb 27, 2004 6:37 am
Bruce,
Clearly your white balance is off. All of the pictures had an unusual tint to them.
Granite
Fri Feb 27, 2004 7:33 am
Hi all
Bruce, yes that blue tint is appearing again. Ain't got a clue what it is.
I remember it being mentioned before......still using the D30?........send me a mail.
Gary Watt
Karlok
Fri Feb 27, 2004 3:44 pm
Maybe try to upload them in 1024x
Granite
Sat Feb 28, 2004 1:17 am
Bruce
Got your mail and responded.
Cannot see this as being a real problem at all. Looking forward to seeing you images  Wink/being sarcastic
Gary Watt
Your Friendly Airliners.Net Screener
Craigy
Sun Feb 29, 2004 9:56 pm
Bruce,
Are you using a different lens for the closer shots or a different aperture setting?
It could be that you need to compensate with different USM setting than you normally use.
Craig.
