Ryan h
Sigma 170 500 Mm APO Lens
Sat Mar 20, 2004 7:09 am
I have just purchased one of these lenses and was wondering if anybody could give me any advice.
dazultra
RE: Sigma 170 500 Mm APO Lens
Sat Mar 20, 2004 7:16 am
I know Rez Manzoori uses this (BIGMA!  Big thumbs up) lens Im sure he'l be happy to give you some tips
Daz.
andyhunt
Crew
Sat Mar 20, 2004 1:55 pm
I use one, what help do you need?
(Gary Watt also uses one, albeit badly!) Big grin
Andrew
Full frame always beats post processing
Ryan h
Sat Mar 20, 2004 5:26 pm
I am having lots of trouble with mine. The camera will let me take one shot and then error 99 will come up on the status screen.
andyhunt
Crew
Sat Mar 20, 2004 6:06 pm
Do you get the same from your other lneses, could be the camera or the lens?
Andrew
Ryan h
Sat Mar 20, 2004 6:31 pm
The kit lens that came with the 300D and a 75-300 mm lens I bought at the time I bought the camera work perfectly.
andyhunt
Crew
Sat Mar 20, 2004 6:44 pm
Sounds strange to me, I just got the D70 and have tried a few test shots, works well. Have you checked the compability lens chart in the manual?
Other Canon shooters........Gary?
Andrew
manzoori
Sat Mar 20, 2004 7:34 pm
Wahay! A Name check! Thanks Daz!  Big thumbs up
Ryan,
Sorry to hear about the problems mate. Just in case you don't know, Error 99 indicates a hardware incompatibility, though quite why it would work once and then not the next is beyond me.
I've not experienced this problem myself but have just googled for the problem and you're not alone! This site has some blogs of people with similar problems... maybe one of them has a fix?
It seems to boil down to Sigma not paying royalty fees to make EF lenses and having to reverse engineer them. Sometimes when a new body comes out they are caught short on the specs.... apparently!
Out of interest is the BIGMA new or S/H? One of the bloggers mentions having Sigma change the electronics in his BIGMA to get it to work.
Hope this helps and I hope you get the problem fixed soon!
Cheers!
Rez
 Big thumbs up
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
Ryan h
Sat Mar 20, 2004 7:49 pm
Mine is secondhand. I will check the site you mentioned to see what it says.
Dazed767
Sat Mar 20, 2004 8:17 pm
I believe that is the same error I had with my Sigma 17-35mm lens on my D30. It only happened once. I just turned it off, took out the batteries for a few mins. After that it was fine, hasn't happened again (happened about 7 months ago).
Justin
AndreasE
Sat Mar 20, 2004 8:41 pm
I'm using a Canon 10D with a brand new Sigma 170-500 mm APO, no problem whatsoever !
Best
Andreas
Craigy
Sat Mar 20, 2004 11:26 pm
My 170-500 is nearly two years old now and works fine on the EOS-30 and 10D.
The very early 170-500s needed to be re-chipped to work on the 10D I believe, but mine is new enough not to have needed it.
Craig.
Granite
Sun Mar 21, 2004 7:11 am
Hi all
Sorry, never came across the error 99 before.
Been using the lens with the D30 for a few years now and with no problems or error messages.
Andrew.....you know I take a good image.......slagging me off makes you look like a tart!
Gary
Ryan h
Sun Mar 21, 2004 8:41 am
Thanks for all the replies.
It looks like that I will have to get it re chipped or if that can't be done get my money back from the shop and buy a new one.
Woody001
Sun Mar 21, 2004 9:44 am
I had the same code appear on my 10D when using an older Sigma lens I'd bought several years ago. It would allow me to take one shot then lock up and display the error code. It seems to happen when the camera alters the aperture setting of the lens, you can check this by setting the camera in aperture priority mode and then picking the smallest aperture (high f number) and then press the depth of field preview button - the camera will lock up and indicate error 99.
Here in the UK Sigma are pretty good and re-chipped my lens in 3 days. It will cost you more if you didn't own the lens from new so my advice would be to take the lens back to the shop and wait until you find a newer version, or get the shop to cough up for the re-chipping fee.
I use the 170-500mm, it's a good lens for the money, just don't expect Canon L quality shots.
Best of luck,
Ian.
If I could just get the afterburner working...
twr75
Sun Mar 21, 2004 9:53 am
I have only had an error99 with the 10D/170-500 combo once, and that was taking multiple shots one after another (airshow) in fairly hot conditions (31 C+ with the camera and lens in direct sunlight). In lulls in the display program I put the camera and lens in the esky to cool things down and it worked OK again until it got hot again. A week later at another airshow in much cooler conditions everything worked OK.
Like a seagull on the MCG of life...
Dehowie
Sun Mar 21, 2004 12:29 pm
G'day Ryan
get onto the Sigma HQ in Melbourne and they will rechip it for free.
If you have a distributor in your state they will post it to Melb for you.
Great service from them.
Just out of interest is the performance of the 170-500 or 50-500 better at the 500mm position when compared to one another?
I got some good rsults at 500mm with the 50-500 but i am wondering if the performance of the 170-500 is better at long range.
Darren
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
rg828
Tue Mar 23, 2004 11:56 pm
Just to clear a doubt I have:
Is the "Bigma" the 170-500 or 50-500 EX?
I dont know the key to success, but the key to failure is trying to please everyone
manzoori
Wed Mar 24, 2004 2:05 am
Depends who you talk to really... I suppose you could say the 50-500 with it's 10x zoom range is the real Bigma, but to me... my beautiful 170-500 is my BIGMA!
Cheers!
Rez
 Big thumbs up
UngoMongo
Wed Mar 24, 2004 2:32 pm
I have read, that here in Denmark, they re-chip is for free.  Smile
Becoming a dad is the greatest.
Ryan h
Wed Mar 24, 2004 9:04 pm
At the moment it is being rechipped for free.
Can anyone offer any tips the get the best from it?
