planedoctor
Scanner Versus Slide
Tue Mar 30, 2004 3:04 pm
Hi there,
I have been a D-SLR user for a quite a while, and now I am learning and discovering slide photography for the fun of it. I have a scanner that a lot of you would probably laugh at--an all-in-one scanner/printer/copier, but it does advertise a 2400x4800 dpi optical resolution, and it gets great reviews in its class. Sure, it is no FS4000 or Nikon CoolScan, but for the amount of money I have invested in digital equipment, and the amount of time I'll actually use film, this is about where my budget hits. That said...
I was wondering if there is a way to test to see if the scans I am getting at 2400dpi are blurry as a result of my camera/technique, or if the scanner is really not giving me true 2400dpi scans. I also don't know if I am just used to DSLR crispness, and film/slide scans just require more tweaking to look sharp. I have tried scanning small things like a Sony Memory stick to see how sharp it comes out, and it seems really crisp that way, so perhaps my slides are just not real sharp. I was using an old beat up second-hand EOS 5, so I really don't know if my scans were not sharp as a result of a third factor being a problem with the camera. I was using "L" glass and at wide angles (or sometimes telephoto with image stabilization) in bright conditions with good shutter speeds, so I didn't think it was a problem with technique in that regard. I have a photo posted at full resolution and unsharpened scan here: http://www.pbase.com/image/27432634 Could someone tell me if this is normal for a scan, or if there is something wrong in the process? (note the image is a not of an aircraft, but I hope to be using this setup to shoot aircraft shortly) Thanks!
-Ken
planedoctor
RE: Scanner Versus Slide
Wed Mar 31, 2004 6:44 am
Could someone who has scanned a lot of slides at 2400 dpi or thereabouts comment on the large photo please, as far as how quality compares?
Staffan
Wed Mar 31, 2004 7:10 am
Not that bad considering it's a flatbed. I'll try to scan a slide at 2800 on my minolta later this evening and post it here.
Staffan
ckw
Wed Mar 31, 2004 8:06 am
Hmm not quite sharp, as you say, but I do think its the scanner rather than your image - the grain in the sky is also soft. If the scan was sharp, grain should be clearly delineated even if the picture was blurry.
Are the slides mounted? I think this could be the problem ... the plane of focus will be on the glass plate, but the film will be floating slightly above this. You could try unmounting the slide, or perhaps the scanner has a focus adjustment.
Colin
Colin K. Work, Pixstel
Staffan
Wed Mar 31, 2004 8:45 am
Here's a Velvia scanned at 2800 on the minolta scan dual 2. Straight from Vuescan with no processing, only converted to 24 bit and saved as jpg compression 10 (2 MB).
Click here
Staffan
planedoctor
Wed Mar 31, 2004 9:37 am
Thank you SO much, you guys. Thanks Staffan for the file- I think my file pales quite a bit compared to yours. I think I need to figure out where the problem is- whether in my film or in my scanner. Colin, the actual film plane is higher than the plane of the glass since the slides are mounted, but that is how the scanner directions tell you to do it. Infortunately I don't think there is an automatic focus. I wish I could figure out how to improve the scans. The all-in-one is still new enough I can return it, but I don't know what I would get in its place. Like I said, digital has been my thing, and the slides are just for fun. My wife really likes the all-in-one, and maybe that is all I will be able to get, so I will have to tweak what I can out of it!
Later!
-Ken
Users browsing this forum: johnr and 15 guests
