airkas1
Crew
Help Needed With Rejection
Fri Apr 09, 2004 3:22 am
Hi guys,
I got this picture rejected today due to badsoft. The screener wrote that I might want to sharpen it a little more. Is that the only thing I have to do then to give it another try?
This is the picture it's about:
http://airliners.net/procphotos/rejphoto.main?filename=NW_DC-10-30_N226NW_08-04kjnewcs2.jpg
Kas
Airliners.net Crew - Head Photo Screener
fireguy274
RE: Help Needed With Rejection
Fri Apr 09, 2004 3:25 am
Looks a little out of level if you look at the horizon...Artie
IL76
Fri Apr 09, 2004 3:29 am
Kas,
It's a little soft and as Artie says, the horizon is crooked.
I hope it won't become too jaggied if you sharpen it further.
How big is the original?
E
airkas1
Crew
Fri Apr 09, 2004 6:05 am
The original is 2032x....
What do you mean by "crooked"? That the picture isn't leveled and that I should rotate it a small bit?
Kas
vafi88
Fri Apr 09, 2004 7:02 am
AirKas, crooked means that your camera isn't level with the horizon, of course, you have to check with the verticals on that, not just the ground.
I'd like to elect a president that has a Higher IQ than a retarted ant.
timdegroot
Fri Apr 09, 2004 7:09 am
Needs about 1 degree ccw rotation I'd say.
Tim
Alderman Exit
