embraer145
Bad Level Or Bad Motiv Or Both?
Tue Apr 20, 2004 4:08 am
Hi everybody.
Is there anybody who can help me with this picture.
http://airliners.net/procphotos/rejphoto.main?filename=BritishMidlandERJ145G-RJXG09-04-04.jpg
It is rejected because of Bad Motiv. My question is: Is it because the picture is not level if you compare it to the runways (If you check the red/white pole above the engine it is level or there must be some really bad engineers at Copenhagen)? Or is it because of the fence in the foreground of the picture. If so do we have to ask the people of CPH-airport to remove or to lower them.
Everybody who has been there knows the situation and it is also known that taxiing traffic taking an early exit from the runway is very close to the spotting point so you can not avoid that a part of the fence is on the picture. If I cut it away with Photoshop you get a very wide but not high picture.
Every advise is welcome.
regards Aart
DAI - Dutch Aviation Images.
JeffM
RE: Bad Level Or Bad Motiv Or Both?
Tue Apr 20, 2004 4:15 am
Bad timing causing the bad motive in my opinion. The excuse of the aircraft being too close causing the fence to fall in the frame can be overcome with a wider lens, or a ladder I would think? Maybe not, but from appearances it would.
Additionally, you cut in half two other aircraft, and have a windsock growing from the fuselage. I would have waited until the a/c cleared those obstructions.
Jeff
timdegroot
Tue Apr 20, 2004 4:17 am
Aart,
Too much of the fence visible, so yes that's why it's badmotive.
Tim
Alderman Exit
mikec
Tue Apr 20, 2004 4:20 am
If rejected badmotiv then it must be the fence in the foreground. I'd have thought it if were the horizon being unlevel, it would have got a badcameraangle rejection
Granite
Tue Apr 20, 2004 4:50 am
Hi all
Agree with the screener who rejected.
Just a little too much going on, birds, fence, antennae, sock, aircraft.
Gary
embraer145
Tue Apr 20, 2004 5:49 am
OK Gary
I will send Copenhagen airport a kind request to remove all obstacles close to the spottingpoints so we can make obstacle free pictures of the aircraft. Do you really think somebody is looking for the fence when he wants to see this picture in the large configuration?
I think it is the disadvantage of me to make pictures of aircraft on the runway or taxiway. And it is clear that not every airport has that much water surround than AMS to avoid fences in sight of the spottingpoints. I like this kind of photography so you can actually see on what airport the pictures are taken. And due to the fact that I have no possibility to take pictures inside the perimeter of the airport or better at the ramp of the airport I have to be happy with a part of a fence sometimes.
I think I start making pictures of aircraft in the approach. Then it doesn't matter what airport you claim as location for your pictures. How can you check that a Airbus A320 of Lufthansa is in Paris, Madrid, London, Copenhagen or whatever.
Just one example: just placed in the database
http://www.airliners.net/open.file/559990/L/
It is only the 67th picture of this B747. Also with a fence at the foreground, half an engine on the picture and a lot of disturbing poles and buildings in the background.
Let me make clear this is only an example. I am happy for Stuart that his photo is added, but the reasons rejections sometimes give me a feeling that it depends on the taste of the screeners who will see the pictures. And I know that every picture is screened by several screeners so that is no excuse.
Aart
JeffM
Tue Apr 20, 2004 5:53 am
".. My question is:...."
You asked.
Let us know how the request to remove all that junk at the airport goes....
v/r
Jeff
Jan Mogren
Tue Apr 20, 2004 5:59 am
Aart,
on that location you need to use a step ladder to get rid of the fence.
Or, you could go to the fence 50 meters to the left and shoot over the fence.
/JM
AeroPresentation - Airline DVD's filmed in High Definition
wietse
Tue Apr 20, 2004 6:04 am
3 things Aart:
1. I understand you are new in this forum so I will be easy on you.
2. It is very bad form to single out pictures from other photographers. Doesnt matter if you say its a good pic or not, it is just not done.
3. Rules are rules, not need to get sarcastic on this one!
Wietse de Graaf
embraer145
Tue Apr 20, 2004 6:38 am
3 answers Wietse
1 I am not new in the forums. Only I am not that active with sending posts. Partly due to my work and partly most of the topics doesn't interest me.
2. As mentioned It is not personal against this photographer. I see loads of topics where pictures are used from several photographers. As well with positive and negative comments.
3. Rules are rules???? I have seen other messages where people are getting hard against hard to each other. As far as I know I have insulted nobody personally. Actually I have only tried to raise a subject. And OK there will always somebody be engaged. I always thought that public forums are meant for this kind of discussions
wietse
Tue Apr 20, 2004 6:56 am
Aart,
ok, but in this case, the answer is pretty clear, not? There is too much rubbish in this pic, thats it. You dont have to react to that by saying:
The rules are the rules in this case!
Wietse de Graaf
embraer145
Tue Apr 20, 2004 7:56 am
Wietse
OK you have convinced me.
In the future I will make "airport anonymous" approach shots. or go back in the winter so I can make pictures of the runway further away from the fence. The problem at this time of the year is the heat disturbance. Which will result in rejections. But don't worry. I am selecting my own pictures and will not even try to upload them because I know it is senseless. And I am a person who will not tire the screeners with pictures of which I know myself they are worthless.
