LHRSIMON
Confused With 5 Rejected Photo's Please Help?
Thu Jun 10, 2004 6:48 am
Hi all. Pretty happy today as almost 20 of my pictures just got added to the site. IM a bit confused though as I have had 5 rejected , but IM note sure for what reason. IM sure the answer is simple but for the life of me after looking at the rejection notice I cannot see whats wrong.
The main problem (4 pictures) is size. I have received a "too small rejection". This states the minimum required size is 1024x768. Now I have had 4 photos at the following size rejected for this reason..
1024 x 810
http://airliners.net/procphotos/rejphoto.main?filename=BA-319-GEUPX-22042004-LHR-SJC.jpg
1024 x 816
http://airliners.net/procphotos/rejphoto.main?filename=BD-A321-GMIDK-22042004-LHR-SJC.jpg
1024 x 810
http://airliners.net/procphotos/rejphoto.main?filename=HY-767-VPBUA-17042004-LHR-SJC.jpg
1024 x 939
http://airliners.net/procphotos/rejphoto.main?filename=JL-747-JA8922-17042004-LHR-SJC.jpg
So im very puzzled so can anyone can tell me what size I need to change them to . I will then re load them as that's the only rejection notice.
Query No # 2
I have a photo that's been rejected twice due to "bad info". Now I have rechecked twice and I cannot see anything wrong. Please help as I fear IM missing the obvious.
http://airliners.net/procphotos/rejphoto.main?filename=GF-A340-A40KD-17042004-LHR-SJC.jpg
Thanks all
Simon
 Smile/happy/getting dizzy
Canon 1D Mk III,Canon 20D+17-40 L f4.0,70-200 L IS USM f2.8,400 L USM f5.6,135 mm L f2.0, 50 mm f1.8,1.4 x II extender
LHRSIMON
RE: Confused With 5 Rejected Photo's Please Help?
Thu Jun 10, 2004 6:53 am
SORRY FORGOT TO ADD THE LINKS CORRECTLY !!!!!!!
1024 x 810
LHR-SJC.jpg>
1024 x 816
LHR-SJC.jpg>
1024 x 810
LHR-SJC.jpg>
1024 x 939
LHR-SJC.jpg>
Query No # 2
LHR-SJC.jpg>
Thanks all
Simon
clickhappy
Thu Jun 10, 2004 6:54 am
was there a note from the screener? They seem to have a lot of dead space around them, esp the Jap 747.
You have the Gulf Air reg as A4zero-KD
The correct reg is A4oh-KD
LHRSIMON
Thu Jun 10, 2004 6:56 am
Sorry but its not letting me add the direct links even though im adding the "< >".  Pissed
Thanks for the help.....
Simon
n907cl
Thu Jun 10, 2004 7:03 am
I just had a photo rejected at 1024 x 628 for size. All other photos uploaded at 1024 x 600 or above have been accepted in the past, so what's the new standard now?
[Edited 2004-06-10 00:17:47]
Brian
LHRSIMON
Thu Jun 10, 2004 7:08 am
Brilliant !!!!!!!! Thats the Gulf air problem sorted !!! I knew it was something stupid. Thanks Clickhappy
Regarding the other photos. Nope , that was the only rejection notice. The reason i left the space at the top was due to the fact i was trying to get a more "square" type picture. I could crop a bit more though if thats what their after. But i gather if that was the case they would have added another rejection notice.
Thanks for the help
Simon
Thu Jun 10, 2004 7:27 am
Ahhh, I had a similar problem with a Gulf air shot and bad info. Time to reload it, I think.  Smile/happy/getting dizzy
syncmaster
Thu Jun 10, 2004 10:03 am
I've had problems with the size rejection too, even though they were all bigger then the minimums. Try using a aspect ratio of 2.5 x 2 (will give you the "square" size), or 3 x 2 (widescreen type size).
They, to me atleast, look soft, they also have a little bit of motion blur, at least to me. But they also seem a little underexposed. That's just my un-professional opinion, there are people here who defenately would be able to help more than I can. Good luck!  Big thumbs up
JeffM
Thu Jun 10, 2004 10:25 am
3x2 is not widescreen. 2:3 aspect in 35 mm pictures produce photographs most commonly measuring 3.5 x 5 inches or 4 x 6 inches.
Just set your crop tool to 6"wide by 4" high and the aspect will work out to 1024x683 pixels.
-Jeff
