Skymonster
Incorrect Info On Photos In The Upload Queue
Fri Jun 18, 2004 1:26 am
All,
We're getting quite a few e-mail requests to change incorrect information on photos that are in the queue. A few things for you all to note:
1. Please check data carefully before you press the final OK - that's what the review after the upload is there for. Use the drop down lists and "I feel lucky" functions as this will result in less errors - correcting errors wastes our time
2. We CANNOT change details on photos in the queue without screening the photo
3. We're not going to give you priority screening (see item 2 above) just because you've got some info wrong
4. Its unlikely we'll remember you got some information wrong by the time we get around to screening your picture in turn
5. So, if you do notice that you've submitted a photo with incorrect information, your choices are:
a. You can ask us to reject the photo badinfo and you can submit it again
b. You can wait and see if it gets rejected badinfo when its processed
c. If it doesn't get rejected, you can submit a correction for yourself once the photo is on the database
Hope this makes sense,
Andy
There are old pilots and there are bold pilots, but there are no old bold pilots
Sabena 690
RE: Incorrect Info On Photos In The Upload Queue
Fri Jun 18, 2004 2:48 am
And may I use this topic once again that for manufacturers like Boeing, both the C/N and the L/N MUST be inluded.
It's amazing how many people upload pics on a daily base with the c/n's and without the l/n's, while this is clearly stated in the explanation field.
Frederic
bigphilnyc
Fri Jun 18, 2004 3:01 am
I have two different resources for getting c/n's and l/n's, but sometimes niehter have them (Anet is one of them).
I add them whenever I can, but if it were easier, the ones I leave blank would be filled in as well.
Any recommendations?
-Phil
Phil Derner Jr.
Jan Mogren
Fri Jun 18, 2004 3:15 am
>both the C/N and the L/N MUST be inluded.<
What good is the L/N ?
/JM
AeroPresentation - Airline DVD's filmed in High Definition
Mriya
Fri Jun 18, 2004 5:16 am
Whoops, I'm guilty of the email-correction by.. hopefully just one instance. Won't happen again  Innocent
Bigphil Have you tried the FAA's N-Number lookup? It's good for planes registered with an n-number. Gives all sorts of neat info. For planes without an N-number such as the foreign carriers, try Google. Chances are you'll find it!
I try to include c/n when I can remember to for the little guys. For the airlines, I try and use the automated feature that pulls up everything about the plane. I also go through my archive now and then to add c/ns when I find them.
Currently not active in aviation photography or this site. Thank you for your interest.
Jaspike
Fri Jun 18, 2004 5:26 am
For example, for G-BYAJ (Boeing 757-200), for the cn field you would enter:
25623/528
...not:
25623
And remember to always try the Auto Complete function  Big thumbs up
Tom
Mriya
Fri Jun 18, 2004 5:31 am
Jaspike
So the 528 part of 25623/528 is the L/N? What does it stand for, line number?
Jaspike
Fri Jun 18, 2004 5:43 am
It does  Smile
For more info on cns, click here.  Big thumbs up
Tom
aviator100
Crew
Fri Jun 18, 2004 8:04 am
C/n + l/n for Boeings and Douglas/MD's can easily be found at http://www.aerotransport.org/, http://www.airlinerlist.com/, http://home.hccnet.nl/p.w.riool/main.html and other sites.
Ad Vercruijsse
database editor
Bronko
Fri Jun 18, 2004 11:09 am
I have been guilty of a few errors recently. I changed my email address for my photos, but when uploading a new photo, the autocomplete feature on the upload page switched my email back to my old.
Clearing it from the MRU (Most Recently Used) cache fixed it. To do so, clear the contents of the email field, and click. You should see a list of all entries, which you can scroll throught. Hit the DEL key on the selected entry and it will be deleted.
Sorry for the error.
This does raise a question however. Now that we can see our pictures in the queue (thanks!), can we see and correct the info belonging to it as well? I could see how this would present a problem if it is being screened however.
Jet City Aviation Photography
bigphilnyc
Fri Jun 18, 2004 2:57 pm
What about body numbers that don't directly tell you what the regi is?
I recently got a badinfo rej on a Comair CRJ. I am assuming it's because I didn't include a regi, but I don't know what it is. I se a body number "7796", but how do I deduce the registration from that?
-Phil
Phil Derner Jr.
Sukhoi
Fri Jun 18, 2004 5:41 pm
Another thing is to make sure the Airline field has an operator included.
Been seeing too many coming through with nothing in this field, if I'm not felling nice and don't want to fill in the info for you I will reject!
Paul
Granite
Fri Jun 18, 2004 5:45 pm
Hi all
And you will get some fanny's adding under the aircraft type as, i.e. '737'
While I could fill in the full Boeing 737-xxx, this is an instant reject as it's total lazyness from the photographer......or total stupidity.
Gary
Skymonster
Fri Jun 18, 2004 5:58 pm
Before this can be allowed, a secured means of allowing each photographer to access their own images and only their images has to be implemented. To do this, it'll be necessary to have a process for photographers to register on the site in a similar way to that in which forum participants are already registered - please don't read anything into this about costs, its a means of identifying each photographer and allowing them to access their own material. Johan is working on this and it'll be launched in due course.
ANdy
Mriya
Sat Jun 19, 2004 1:10 am
Skymonster I'm happy to hear that Johan is working on that! No doubt it'll help make corrections easier and take some load off the screeners. A.net gets better everyday  Big thumbs up
