Granite
Sensor Dust - A Screener Request
Fri Jul 09, 2004 9:17 pm
Hi all
With all the new crop of digitals going around more and more images are being uploaded with sensor dust/spots visible.
While this may have not been a major problem in the past, it is now and the BADDIRTY rejection reason will come into play more often.
If anyone get's this rejection reason, please don't rant and rave. It's a friendly warning from your screener to say your sensor needs cleaning.
There have already been discussions on this forum on how to detect the spots.
Being a screener for about 5 years now, I can spot them straight away so none will get past me  Wink/being sarcastic
So..........before you upload, check the image for spots in blue skies and even cloudy ones, depending on contrast.
Any questions, just ask.
Gary
mirage
RE: Sensor Dust - A Screener Request
Fri Jul 09, 2004 9:23 pm
Can you make that text an email to be send to all photographers?
We know this forum is not visited by all...
Luis
Granite
Fri Jul 09, 2004 9:38 pm
Luis
A good idea and I will have to pass on to Johan to see if he can mail all.....thanks.
On a separate note, I supply aviation images to a professional agency and have been instructed by them to ensure that all sensor spots are erradicated before being passed on to the customer.
Gary
sulman
Fri Jul 09, 2004 9:41 pm
Gary,
Quick question. Are dust spots always semi-transparent, with a 'circular' appearance?
Reason I ask is that I think I've been eradicating little birdies from my images..whereas I only have one speck of dust in the bottom left that I'm actually aware of...
James
Granite
Fri Jul 09, 2004 9:51 pm
James
Yep, you are correct.
I've mentioned this a million times, invest in a Speckgrabber. One of the cheapest, most valuable items you can have in your camera bag.
Gary
kaddyuk
Fri Jul 09, 2004 10:58 pm
I have had one or two of these and now am more aware of them in my pictures  Smile
JeffM
Sat Jul 10, 2004 12:46 am
To find your dust, just open an image and click Image>Auto Levels. Most of the time doing that will show you some hidden dust you did not know was there. Inversing the image and then doing the Auto Levels will also show you some hard to find dust.
Woody001
Sat Jul 10, 2004 1:07 am
Gary,
I cleaned my sensor last weekend before a visit to Old Warden, they're in the queue, makes processing images so much quicker. It's surprising just how quick dust builds up on the sensor and I'm a fussy bugg@r when it comes to changing lenses  Smile
I tend to let it build up to a certain level and then clean it.
I agree with the e-mail idea.
Ian.
If I could just get the afterburner working...
beechcraft
Sat Jul 10, 2004 3:16 am
Hey Gary,
i guess you did a lot of screening from my last upload.  Smile/happy/getting dizzy
My first with my D70, I´ll be more aware of those dust spots from now on....
best regards, Denis
That's it! You people have stood in my way long enough. I'm going to clown college!
2912n
Sat Jul 10, 2004 5:30 am
In response to a question above about how they appear...Yes, they usually appear as a spot, almost translucent. However you might get a fiber or hair in there that will look like a squigly line.
lennymuir
Sat Jul 10, 2004 9:35 am
Gary
I presume to you can differnetiate between sensor dust and the Scottish midgie!
Midgies tend to be darker and smaller on the photograph.
Unavoidable when shooting in over grass or within the vicinity of trees after rainfall.
Midgie = a very small fly, like a mosquito, but much more annoying!
Gerry
Granite
Sat Jul 10, 2004 7:22 pm
Hi all
A link to some more info on sensor cleaning:
http://www.luminous-landscape.com/essays/sensor-cleaning.shtml
Thanks to Yvan for his e-mail.
Gary
Granite
Sat Jul 10, 2004 7:24 pm
Gerry
No real problem with Midgies at ABZ..........only sheep and wasps  Smile
Gary
Karlok
Sun Jul 11, 2004 4:00 am
Instead of email every photographer it is also possible to ammend the rejection text. or just add the text like
"If you use a digital SLR, you should check your sensor from any dust. But be aware with it, it's sensitive and expensive. Airliners.net is not responsible for any damage."
Just an ide.a.
donder10
Sun Jul 11, 2004 4:50 am
Gary,
do you have the URL for speckgrabber?
qantas744
Sun Jul 11, 2004 5:23 am
you can't buy time but you can sell your soul and the closest thing to heaven is to rock'n'roll
concord977
Sun Jul 11, 2004 6:13 am
I am sure I have a dusty CCD problem with my D100. I found a source for speckgrabber locally. But is this something I can do myself?
No info
lorm
Mon Jul 12, 2004 10:09 pm
Kinda new here myself with higher end digital cams, and I'm not sure it's sensor dust but in some photos on A.net there are small circles that are bluish or sometimes violet specs. Is this CCD dust or a problem with the sensor itself?
Brick Windows
Granite
Mon Jul 12, 2004 10:18 pm
Lorm
That may be lens flare.
Would need to see some samples.
Gary
lorm
Tue Jul 13, 2004 12:09 pm
Granite/Gary,
Okay this is a tough one because its one
of my favorite images from my home
airport. It's actually a green spec this
time. But in images I less remember they
appear blue or violet.
Center frame lower half of the image is
a green spec. It looks digital and not
part of environmental conditions.
Photo © Ray Harvey
Edit: Actually if you go Normal View Large Size mode when looking at the image it lines up vertically with the "F" in Fit Screen from "[Medium Large Fit Screen]"
[Edited 2004-07-13 05:19:07]
Brick Windows
Granite
Tue Jul 13, 2004 4:00 pm
Lorm
Possibly a 'hotspot'
This can easily be cloned out with Photoshop but I cannot see it as being a problem.
Gary
