patroni
Photoshop Elements
Thu Aug 12, 2004 2:02 am
Hello,
I am using Photoshop Elements 2.0 which came together with my Camera. In general I am quite satisfied with it, except one thing that I could not solve yet:
How do I keep the 1.5:1 width/height ratio of the pictures when cropping? I know that I can set a width of, say, 1024 pix and a height of 683 pix in the crop tool, but how can I use it just with a ratio of 1.5:1, regardless how big the size will be? E.g. if I want to crop but keep the current size of the cropped portion.
Have looked at the help file but as I don't know which technical term to look for, the help was rather useless for me  Sad
Any suggestion?
Thomas
futterman
RE: Photoshop Elements
Thu Aug 12, 2004 2:19 am
Thomas,
Try holding down 'Shift' when dragging the corners. It should preserve all the whatchamacallit ratios.  Big grin
Brian
What the FUTT?
patroni
Thu Aug 12, 2004 2:48 am
Thanks Brian,
but nope, doesn't work for me..... It keeps the ratios nicely even without pressing shift when I entered the values in the box. But without this, no solution so far...
Thomas
Kereru
Thu Aug 12, 2004 5:16 am
Thomas,
You should be able to select Constrained Aspect Ratio in a field on your tool bar when you have the crop tool selected. Then there will be two boxes next to it where you can enter 1.5 to 1 etc. There is a normal setting as well I think. I have an early version of Photoshop so may be a little different layout.
Search for Constrained Aspect Ratio in the help menu if the above doesn't work.
Colin
Good things take Time.
patroni
Fri Aug 13, 2004 8:00 am
Colin,
aaaah... actually quite easy! Thanks to your help I knew what words to search for and found the solution. Great, thanks a lot!
Thomas
Users browsing this forum: Catalin81 and 1 guest
