volare
Sigma APO 50-500 Vs APO 100-400 SO
Thu Aug 12, 2004 6:51 am
Hello,
I have a Sigma 50-500 and not yet used as I want; few shots and only 10/15% acceptable (most of my shots are too soft).
I sent the camera to Canon (10D) to be checked and it is ok.
So now my question is: would I try to buy a new Sigma100-400 SO, or in case of airplane shots the SO/IS systems are not necessary?
The lens itself is good, because sometimes I have a very sharp images, so I believe that the problem cold be solved by SO/IS system.
Please let me have Your advises.
Max!
aviopic
RE: Sigma APO 50-500 Vs APO 100-400 SO
Thu Aug 12, 2004 7:00 am
you might be using your lens as if it was mounted on a analog camera.
Don't forget when shooting at 500mm it will be 800mm when mounted on your 10D which of course affects the exposure time you can use.
You might try a one-leg or a tripod.
The truth lives in one’s mind, it doesn’t really exist
volare
Thu Aug 12, 2004 7:06 am
Thanks for answering.
Do You think that a monopod will help me in having sharpen pictures, even if I usually shoot with panning?
Max!
clickhappy
Thu Aug 12, 2004 7:25 am
Max, are you referring to the Sigma 80-400 OS?
The only other lens in that size range would be the 135-400mm f/4.5-5.6 but it doesn't offer OS.
aviopic
Thu Aug 12, 2004 7:28 am
It will help for sure but panning with 800mm mounted on your camera will take some practice to get it right.
If you are not using a monopod try to shoot faster then 1/800 of a second(at 800mm that is) or try 1/1000s and see if that helps.
Of course you need enough light and/or going back to ISO 200.... 400
At least it will tell you where the problem is, you or the lens.
Best of luck,
Willem
Dehowie
Thu Aug 12, 2004 3:57 pm
Hi Max
The 50-500 is not something you can throw on a 10D and have immediate success with.
It takes a fair bit of practice to get you technique down and your success rate up.
You really need to practice to see great results.
As a test of sharpness put it on a tripod and check the results which will probably be very sharp.
Technique is everything.
Darren
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
airportugal
Thu Aug 12, 2004 6:03 pm
Hi Max,
I've been using the Sigma EX80-400 and with some good results:
Photo © Luis Gonçalves
It is a good option over the 50-500 due to the OS.
Best regards
Luis
volare
RE: Sigma APO 50-500 Vs APO 80-400 OS
Fri Aug 13, 2004 12:42 am
Hello,
sorry was very late for me last night..... I was meaning Sigma 80-400 OS.....
I will make more practice to see if it is me (I think so).
Thanks to all for You help/suggestions.
Bye Max!
Ps. very nice shoots Luis....
