Bad Double?
Sun Aug 15, 2004 6:26 am
I tried to post this image
http://www.airlinerimages.co.uk/Newadditions/Farnborough_F18_Boeing.jpg
It was rejected due to bad double clashing with this image, with a warning I could be suspended for posting doubles.
http://www.airliners.net/open.file/627403/L/
I asked for the above image to be removed and it was not, I then asked for it to be replaced with the one rejected and was told its a different frame.
I have noticed some photographers have many images of the same aircraft at the same event. Why then are mine classed as bad double or is it double standards??
wietse
RE: Bad Double?
Sun Aug 15, 2004 6:33 am
Wietse de Graaf
wietse
RE: Bad Double?
Sun Aug 15, 2004 6:34 am
The plane is pointing in the same direction, it is in the same stage of flight, and add to that, there are TONS of different images of this performance in the database. One moment there is just enough! Its just bad luck you are the one.
Wietse de Graaf
eksath
Crew
RE: Bad Double?
Sun Aug 15, 2004 6:52 am
..still both shots are good!...I liked them both. Nice job.
World Wide Aerospace Photography
RE: Bad Double?
Sun Aug 15, 2004 7:21 am
Wietse
I thought according to the FAQ you could request an image to be deleted allowing an alternative to be uploaded into the queue for screening?
yevgeny
RE: Bad Double?
Mon Aug 16, 2004 12:42 am
Wieste if you will judge this way it means every second photo on A.NET is "BAD DOUBLE"
Some sample:
Photo © Ben Pritchard
Photo © Derek Pedley - AirTeamImages
Photo © Spencer Wilmot
Photo © Rotate
Photo © Aaron Lupton - AirlinesOnPrint
Photo © Anthony Osborne
Yevgeny
RE: Bad Double?
Mon Aug 16, 2004 12:55 am
That's a good response Yevgeny, but not being one of the chosen few means it would never be accepted no matter which direction it was pointing.
I have seen some photographers with up to several images of the same aircraft pointing the same way on the same day Wink/being sarcastic
It was more of a case of how I could get one image removed and try to get a new one accepted, without getting a bad double or bad frame response.
ChrisH
RE: Bad Double?
Mon Aug 16, 2004 1:03 am
Baddouble only applies to when the same photographer uploads similar shots Yevgeny. The example above would've been badcommon if anything, but they're all high quality shots so...
what seems to be the officer, problem?
Leezyjet
RE: Bad Double?
Mon Aug 16, 2004 5:56 am
Not being an expert but the 2 pictures are clearly differant.
Both are great pictures.
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
