schreiner
How To Improve My Photo?
Thu Sep 09, 2004 10:55 pm
Well, I'm a bit experimenting with my new dig-cam. I've made a few photo's and submitted to a.net. They were refused. No bad feeling offcourse because I'm still a rookie and still practicing with my new cam. But I thought that this was a nice try actually. What can I do better next time? Weather was good, spot was ok... What's wrong? Thanks for all your help and replys.
click for my first try
Schreiner
Soaring the internet...
Interpaul
RE: How To Improve My Photo?
Fri Sep 10, 2004 12:40 am
What was the rejection reason?
schreiner
Fri Sep 10, 2004 12:46 am
- 0209045.jpg (Martinair McDonnell Douglas MD-11F)
The image quality of these photos is low. This may be the result of several
perceived problems happening simultaneously, such as grain, blur, lighting,
contrast or color defects, which would lead us to believe that a fresh scan
(in the case of a non-digital image) or a complete rework starting with the
original camera file (in the case of a digitally taken image)would be necessary,
rather than a simple adjustment to the uploaded file.
It could be caused by the scanner you are using, the way you scanned your
photos, the (digital) camera, the light conditions when you shot the photos,
object out of focus, improper photo manipulations or any combination
thereof. Most of the time, the cause is either a bad scanner or that the
scanner wasn't used properly. If you think this might be the cause, please
read the documentation for your scanner and find the best DPI and color
settings. Generally a higher DPI and color setting will make a higher
quality image but only to a certain degree and it differs between different
brands of scanners. Try many different settings until you find the best
combination. If you are using an old or low quality scanner you might
consider investing in a new or borrow one from your friend/workplace/school.
If you are using a digital camera, check camera settings, please be aware
also that ,unprocessed, digital camera output is generally not
of acceptable quality for airliners.net. If you are using a lower quality digital
camera with a resolution below 3 Megapixel you might consider investing in a
camera with higher resolution or borrow one from your friend/workplace/school.
A frequent source of this problem is when the photograph was taken under
poor weather conditions without appropriate corrective measures (such as
exposure). Note that making acceptable photographs in poor weather
conditions or at night is quite difficult, and you should perhaps try to
achieve a good level of expertise and a few successful uploads of good
weather photographs before attempting much more difficult poor weather
or night photography.
If you think you have been able to improve the quality of the photos,
please re-upload them. Note that we are still very interested in
having these photos in our database, we only ask that you try to improve
the quality of the digital version of your photos. You can find examples
of photos with a high quality scanning in out "Editor's Choice"
section linked to from the front page of Airliners.net.
The photos were soft. This doesnt mean they are blurry (like motion
blur). It means that they could need this extra kick of sharpness.
This target can be reached by using the sharpen function of your
Photoediting program. For example in Photoshop try the Adaptive Unsharp
mask. But be careful not to oversharpen your pictures. Oversharpening can be
identified by jaggies. This is when a line that should have straight borders
has borders that look like stairs. Most scanners will not provide a very
sharp image without such post-scan manipulation. Raw digital camera output
is generally not of an acceptable standard for airliners.net without some
form of post-processing.
If you think you have been able to improve the Sharpness of the photos,
please upload them again. Note that we are still very interested in having
these photos in our database, we only ask that you try to improve the
sharpness of the digital version of your photos.
So... it can be anything?
LHSebi
Fri Sep 10, 2004 7:10 am
Looks like jpeg compression to me there. But that's just me  Big grin
Sebastian
I guess that's what happens in the end, you start thinking about the beginning.
DIJKKIJK
Fri Sep 10, 2004 11:30 pm
I think I can tell you why, there may be other opinions too.
The picture is clearly of sub-optimal quality. Just look at the cockpit windows and their edges for example , they seem to be rather wobbly.
Here are some good nose closeups
Photo © Jerome Zbinden
Photo © BAIRES Aviation Photography
Photo © Nacho Piédrola - IBERIAN SPOTTERS
BTW, where exactly in schiphol did you take that picture ? Looks like on ehll of a spotting location!
Never argue with idiots. They will bring you down to their level, and beat you with experience.
schreiner
Sat Sep 11, 2004 1:10 am
Okay, I know what you mean... but I thought it was sharp enough. I cant sharpen the image more with photoshop, because it will get worse while doing that. Is there a way to improve the sharpness of my next images by changing my way of photo taking?
Here are the settings:
bits: 24
Resolution: 230 *230dpi
Shutterspeed: 1/1024 sec
F: 4.9
Focus: 63 mm
Thanks for any commends!
Schreiner
BTW: The spottingsite is at the crossing of the "hoofdvaart" (Hoofddorp) and the taxiway to 36L Polderbaan. (pssss... our secret..  Smile)
spacecadet
Sat Sep 11, 2004 6:24 pm
The image is already over-sharpened a tad; I wouldn't sharpen it more, and would actually sharpen it less. You've got halo effects around all the high-contrast edges, and some of the noise is probably exacerbated by the sharpening.
What camera is this? I ask because you say you're using f4.9. If it's a point and shoot camera, you may not be able to do much better, but most SLR lenses have a "sweet spot" at between f5.6 and f11. Try that and your photo may be naturally a bit sharper next time - it looks like you used either a long zoom here or telephoto, so you'd want to be in the sweet spot of the lens for the best natural sharpness.
I also personally think it's a tiny bit too tightly cropped on the nose, but it probably wouldn't get rejected for that. There is a sort of "rule" in photography, though, that when you have an object that appears to be going somewhere, you give it a little bit of room in the photo so it doesn't look like the photo is "trapping" the subject (alternatively, many photos break this rule on purpose specifically to suggest the subject is trapped). But that's subjective; I don't think that's why it got rejected. But personally I'd suggest just giving a tiny bit more space in the crop next time; maybe another two feet off the nose of the plane.
INNflight
Sat Sep 11, 2004 7:37 pm
Start from the original file again, crop, resize the image to 1024 x 7** pixels and sharpen it. You might want to use NeatImage to get rid of the noise.
Keep trying.
Florian
Jet Visuals
schreiner
Sun Sep 12, 2004 12:34 am
Great tips guys, thanks alot.I downloaded NeatImage but don't get it yet. Working on that.
But; how to kill the halo effect? Is that because of the zoom? Will a tripod help?
The camera is a Kodak DX6490, not a slr but "close". It's a good camera with a Schneider lens (10 optical zoom) and a PASM feature so that I can learn how and what when I buy an SLR.
Thanks again, I'll keep trying. Ive some others still in que.
Schreiner
spacecadet
Sun Sep 12, 2004 4:14 am
The halo effects are from oversharpening, whether you did it yourself in post-processing or the camera did it. Some cameras have in-camera default sharpening settings that are too high as it is.
I just checked out the Steve's Digicams review of this camera, and looked at some of the sample photos there. They also have halo effects, for example look at this shot:
http://www.steves-digicams.com/2003_reviews/dx6490/samples/101_0071.JPG
Look at, especially, the edges of the red boats vs. the blue sky. There is a hard halo effect there similar to what's in your shot. So it seems like this is in-camera over-sharpening. Is there a "low sharpening" mode or something similar on this camera? (Or an actual sharpness setting like on an SLR?) I don't know much about this camera. That's probably the only way you could get rid of the halo effects, if there's some way to turn down the sharpening in the camera.
The review itself also says the jpeg compression in this camera is a little too aggressive and so some of the noise in your photo (like that boat photo too) is probably caused by the compression. Do you have the settings turned up to max quality and size?
NeatImage will definitely help with the compression noise; just don't be too overly aggressive with it. Use the preview feature and spend some time tweaking the settings so your photo has less noise but still looks natural.
Oh, and you asked about a tripod - a tripod would help your sharpness, that's the point of them. I don't personally think softness or blurriness are a big problem with this photo, though. But a tripod is good to use when you can just to ensure you're getting the best sharpness possible. They're not always convenient and you might not always want to (or be able to) use one, but you should at least have one as part of your equipment package. Having more than one is ideal - for example, a nice, big, heavy one for when you're going to plant yourself on the end of a runway somewhere for a while, and a tiny little travel tripod for those days when you just want to walk around with your camera. (A travel tripod is only like $20, so definitely worth buying.)
[Edited 2004-09-11 21:21:47]
schreiner
Sun Sep 12, 2004 9:39 pm
Spacecadet: thank you very much! I'm now testing my cam with different sharpness-settings. I'll keep you updated. Let's see if my photo's that are in the que right now will get accepted.
Schreiner
schreiner
Sun Sep 12, 2004 11:44 pm
I've got some in que where I can not find the halo effect, so the has to be something different. I guess that I need to correct the lighting a bit when shooting with much zoom and very sunny conditions. Is this a reasonable explanation?
Pic in que
Schreiner
IL76
Mon Sep 13, 2004 12:05 am
I don't think that picture will make it either. Quality is alright (although a bit soft) but you could have clipped off 150 pixels on the left. It's not centered very well.
Eduard
Another waving captain from Amsterdam... Jippee!  Insane
