MADtoCAE
Worth Uploading?
Sun Sep 19, 2004 1:07 am
Is this photo worth uploading?If its not How can I improve it?
This is the photo:
http://tineypic.com/5n38h
Operator!!! Give me the number for 911!!
zhukov
RE: Worth Uploading?
Sun Sep 19, 2004 1:20 am
I think the link is broken...
F.Breit.
bigphilnyc
Sun Sep 19, 2004 1:21 am
Link doesn't work.
(Philler)
Phil Derner Jr.
Interpaul
Sun Sep 19, 2004 1:24 am
I hope he didn't mean this one:
http://tinypic.com/5n38h  Confused
Jan
MADtoCAE
Sun Sep 19, 2004 1:26 am
What do I use,URL TAG or IMG?
MADtoCAE
Sun Sep 19, 2004 1:30 am
Its that one.I guess its not worth it.
bigphilnyc
Sun Sep 19, 2004 2:00 am
No, I dont think it would get accepted.
Phil Derner Jr.
timdegroot
Sun Sep 19, 2004 2:01 am
No this will not make it on here.
It could be improved by removing the border on the bottom right/making it smaller/and maybe lightening up some areas, but it will never be a.net quality.
Tim
Alderman Exit
MADtoCAE
Mon Sep 20, 2004 4:57 am
Is this A.net quality?
http://tinypic.com/5ques
Would it be better to crop the date or cover it?
zhukov
Mon Sep 20, 2004 5:19 am
It looks like if it were overcompressed... what kind of file is it ? .bmp ?
I would say :
- badlevel
- the date on the right-bottom corner has to be removed
- would need cropping and downsizing to 1024-768
- once again, looks overcompressed, or too much digital grain, I don't know exactly, but it isn't sharp enough for A.net quality I think.
Is this file the original picture ? If it is I think it would be difficult to have it accepted, even with postprocessing with photoshop.
Just my opinion though...
Flavien
edit:
PS: what is the camera you are using ?
MADtoCAE
Mon Sep 20, 2004 5:43 am
Thanks Flavien.
I put the file under .jpg.
I cant see the bad level.Where do you get photoshop?
Camera is a nikon coolpix 3700.
What do you think I should crop?
zhukov
Mon Sep 20, 2004 6:22 am
I have tried some post-processing with your picture : after that it is obvious for me that one major problem is the over-compression of the picture.
Try uploading the original picture, exactly the one you have extracted from the storage card of your camera. If this one is also overcompressed, then next time you take pictures, you should choose in your camera setting the highest resolution - lowest compression option. Don't try saving this .bmp (?)picture in a jpeg file, as it would be even worse.
Concerning the bad level, I'm not 100% sure, but I would rotate the picture to the right by 0.5° or 1°.
What do you think I should crop? the aircraft is too small compared to the entire picture, crop from the left until the airport tower, and from the right so that it will be about 1cm left between the aircraft and the right frame of the picture. Try to keep approximatively a 3/2 lenght/height ratio. Crop also this ugly orange "19.09.2004"  Big grin
Where do you get photoshop ? you can get it on computer shops, however it is quite expensive. You can also use another picture editing program.
Once again, the major problem is that the quality of this picture is bad, I think mainly because of the too high compression. If you can give me a less compressed file, maybe I can process it for you with photoshop.
Flavien
MADtoCAE
Tue Sep 21, 2004 12:09 am
Thanks.
Why is it overcompressed?
zhukov
Tue Sep 21, 2004 12:37 am
Why is it overcompressed ?
You obtain this overcompressed result when :
- you haven't settle the finest picture quality option of your camera. Usually you can choose between 1MB - 2MB - 3MB etc. pictures, and also the jpeg compression ratio. Look at your camera handbook for more details.
- after having downloaded the picture from you camera (storage card) to your computer, you have opened the picture with a program like "Paint" or something else and, after some modification, you have saved this picture on your harddisk. This kind of cheap image editing programs saved your pictures with far too much compression.
On your picture, this overcompression is visible near the airplane's windows, for example, near the registration, and in the entire sky; it is clearly visible there after some "sharpening" with photoshop.
I ask you once again, is the picture you post there http://tinypic.com/5ques the original one, i.e. comes it directly from your camera storage card ? or have you modified it, even slightly ? or changed the three last letters of the file (.jped .bmp .tiff etc.) ?
Flavien
MADtoCAE
Tue Sep 21, 2004 1:26 am
Flavien, I've changed the last three letters.The stupid thing is that I don't know where the hard drive is.
MADtoCAE
Tue Sep 21, 2004 4:19 am
How do you want me to give you the photo,Flavien?
zhukov
Tue Sep 21, 2004 4:36 am
You should have received an email from me.
Flavien
