timdegroot
10D Battery Charger
Sun Sep 19, 2004 6:14 am
Have been noticing some strange behaviour from my batter charger.
It tends not to fully charge batteries in one go, usually it only loads for half an hour and then says the battery is fully charged. When I remove it however and restick it in the charger it begins to load for another half an hour or so....
It's not the batteries, because it does it on all 3 batteries I use.
Anyone had similar problems?
Tim
Alderman Exit
Airplanepics
RE: 10D Battery Charger
Sun Sep 19, 2004 6:46 am
Tim,
I had the same problem a few months ago. I cleaned the contacts and it seemed to work fine after.
Simon Nicholls
Simon - London-Aviation.com
aviopic
Sun Sep 19, 2004 6:57 am
That was what i was going to tell Tim as well Simon  Smile/happy/getting dizzy
Clean the battery contacts also Tim, use some alcohol and a "ear stick" or what ever it is called in English.
Willem
The truth lives in one’s mind, it doesn’t really exist
tom3
Sun Sep 19, 2004 6:59 am
I had also the same problem, so I put the batteries 2 times or so in the charger to get it full loaded!
Tom - Lap
Tom Mousel - Lap
ua935
Sun Sep 19, 2004 7:01 am
Evening,
From what I understand the charger works on a timer, it does not know whether the battery is empty or fully charged, just how long the charger has been on for when a battery is in situ.
I might be wrong, please correct me politely if so.
Regards Simon.
Live every second like you mean it
timdegroot
Sun Sep 19, 2004 7:18 am
I'll try the contact cleaning next time, thanks guys.
Tim
Alderman Exit
