LHSebi
Help With A Badlevel Rejection Please
Sun Sep 19, 2004 10:59 pm
Hello all,
I just got this photo rejected for badcameraangle/baddark:
http://airliners.net/procphotos/rejphoto.main?filename=DALPG_sept12_dus.jpg
Any thoughts on this? About the badlevel, I opened it back up in PS, put the grid in, and it seems level to me. The problem with using the lamppost in the upper-right side is that it narrows as it gets higher, making it look like the picture is not level. Or is this just my imagination? Please help me!
About the dark, it's a night shot...wouldn't cranking up the brightness take away from the feeling of a night-shot? Thanks!
Sebastian
Disclaimer: I am in no way trying to complain to the screeners, but hoping someone can help me see what they saw!  Smile Thanks!
I guess that's what happens in the end, you start thinking about the beginning.
Interpaul
RE: Help With A Badlevel Rejection Please
Sun Sep 19, 2004 11:26 pm
Nice shot, but I think it needs some cw rotation.
Jan
[Edited 2004-09-19 16:28:28]
Karlok
Sun Sep 19, 2004 11:34 pm
The subject of the photo looks quite dark, It's possible to increase some contrast. The pushback truck is almost invisible over here.
TZ
Mon Sep 20, 2004 1:27 am
baddark: The LTU aircraft is too dark - details are not visible. You are struggling because of the brightness of the aircraft in the background.
badangle: Absolutely needs a CW rotation. Compare your lamppost and building verticals.
Tamsin (a.net screening crew)
TZ Aviation - Aeropuerto de los Banditos Team Images
zhukov
Mon Sep 20, 2004 1:44 am
Hello,
I would rotate it by around 1.5° to the right, add brightness and contrast (would say respectively +15 and +20 if you work with Photoshop).
The problem, as said Tamsin, is that the other aircrafts then look too bright.
I like your picture very much however, specially the blue light coming out of the aircraft's windows.
Flavien
LHSebi
Mon Sep 20, 2004 2:32 am
Thanks to all of you for your constructive comments. I will try to fix it. Thanks!
Sebastian
