draigonair
Hmm Not Too Sure About This ....
Sat Oct 09, 2004 5:30 pm
Hey guys
i just got some rejection i need some help with because i dont really understand them....
this one: Badmotiv
http://www.airliners.net/procphotos/rejphoto.main?filename=DElta1604nose.jpg
Bad camera angle:
http://www.airliners.net/procphotos/rejphoto.main?filename=USair762.jpg
Bad Common (i never took a pic like this)
http://www.airliners.net/procphotos/rejphoto.main?filename=MartinprinsberjunTAK02.jpg
Bad Info??
http://www.airliners.net/procphotos/rejphoto.main?filename=UNITED772towerbehind.jpg
ok i have no clue whats wrong with these pictures...
please help me
cheers
Nick
cheers
paulinbna
RE: Hmm Not Too Sure About This ....
Sat Oct 09, 2004 5:52 pm
The first one: I don't really know
The second one: Look at the yellow sign all the way to the left in front of the aircraft it is not level. CW rotation
Bad common means there are alot of this aircraft all ready in the database 128 to be exact. Which in my opinion should not matter. (just my opinion)  Smile/happy/getting dizzy  Smile/happy/getting dizzy  Smile/happy/getting dizzy  Smile/happy/getting dizzyas opposed to bad double which the same picture you uploaded.
Bad info: you do not have a reg number it is fairly easy to find out from what the reg number is from the number on the nose.
Hope this helps.
Paul
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
draigonair
Sat Oct 09, 2004 5:58 pm
thnx,
yeh i tried to find the reg of that UA, but none of the plane in the database have a number ETOPS 2369...ill try and look....
cheers
Nick
cheers
QANTAS077
Sat Oct 09, 2004 6:00 pm
bit rough with the Delta, the UA is awesome, just add the rego.
Lurch
Sat Oct 09, 2004 6:08 pm
HI
The UNITED Code 2369 is from a 777-222 N769UA LN-12 C/N-26921.
The info came from my copy of AFQR by Air Britain.
draigonair
Sat Oct 09, 2004 6:10 pm
yeh cheers mate i found th reg also  Smile just had to figure out how the ETOPS was also part of the reg  Smile
also this is wierd
this one badcommon:
http://www.airliners.net/procphotos/rejphoto.main?filename=KLmoedteresaTAKnose.jpg
and then this (delta) bad motiv...
this one also bad common...
hah suggestions on what to do?
cheers
[Edited 2004-10-09 11:11:55]
cheers
Interpaul
Sat Oct 09, 2004 6:33 pm
The Martinair is a beautiful picture but the problem is this.
Photo © Lukas Kinneswenger
Photo © Simon Willson
Photo © Romailler Lionel
Photo © Jan Davidts
Photo © Alexander Jonsson
Photo © Paul Spijkers
Photo © Wietse de Graaf - AirTeamImages
Photo © Miguel Snoep
Photo © Ruud de Vries
Photo © Ramon Berk
Photo © Florian Kondziela
Photo © Alexander Gregory
 Wink/being sarcastic
Jan
draigonair
Sat Oct 09, 2004 7:13 pm
yeh true...
tried to edit some, and some i didnt use again but this one...
what should i do with it?
just leave it or re-upload?
cheers
cheers
jderden777
Sun Oct 10, 2004 5:24 am
also that last one, the UA 777 might need to be rotated a bit CCW
jonathan d.
EDIT: nevermind i just saw your other thread about rotating the same picture....
[Edited 2004-10-09 22:25:32]
"my soul is in the sky" - shakespeare
Dazed767
Sun Oct 10, 2004 10:00 am
Nick, maybe the Martinair should have been baddouble becuase you already had a shot in the DB, but your second one is just a close up on departure. Just my opinion.
Rotate
Sun Oct 10, 2004 11:01 am
aloha guys,
srry, but all pics are just okay! cant see anything, why there are not going into the DB. ok, the reg on the 777 from United shouldnt be a prob to get. rejections by new screener/in training? Appeal! the Delta Shoot is very nice and I really like it, but be aware, if its going to get accepted, it will be exactly 1 hrs before 24:00  Wow!
Robin
ABC
clickhappy
Sun Oct 10, 2004 11:48 am
1) Not so bad really, but this is one of those odd shots, more than just the nose, but not an entire airplane. I would reject it as badmotiv.
2) Needs some slight CCW rotation. I have to say, I am surprised you dont have the reg numbers of these planes, as you are pretty close to the action. How come?
3) Not too bad, but 125+ shots ahead of yours, it will take something pretty special to get in at this point. Just looking at the above thumbnails I see 6 images with more or less the same angle as yours.
4) Very unlevel. Also lots of evidence of chromatic abrasion with your lens. Of course its also missing the reg number.
spacecadet
Sun Oct 10, 2004 1:19 pm
See, this is a travesty. Rejecting a shot just because it doesn't pigeonhole perfectly into one of the categories here. Out of all four of these shots, this is the one I couldn't stop looking at. It's rare to see a pic where you can see both the flying pilot and (maybe) some of the passengers, in flight.
(I'm guessing you mean "chromatic abberation".) I don't really see any purple fringing, except for one small spot of it where the landing gear intersects the white lamp-post; it's not really the type of shot that'd exhibit a lot of CA, though.
I do see over-sharpening. There are noticeable halo artifacts around almost everything, as well as extra noise throughout the image caused by over-sharpening. A simple rotation and less sharpening would improve this image.
tu154m
Sun Oct 10, 2004 1:21 pm
The DL shot is cool. For god's sake....... you can see the condensation off the nose gear doors, the individual rivets with paint missing.......you can almost see the pilots big fat wallet!!!!!!! I think badmotiv is just a convienient rejection........that's a cool shot, no reason at all not to be added. In fact, they are all quite good. The bad double really blows too........that could apply to just about all aircraft here, especially special schemes and such.
S
CEOs should swim with cement flippers!
clickhappy
Sun Oct 10, 2004 4:36 pm
How is it a travesty? I'm sharing my opinion, no need for drama  Smile
The good news is you can always appeal the shot, surely if it is good Johan will let it in.
And yes, I meant chromatic abberation. Thank you for pointing that out.
draigonair
Sun Oct 10, 2004 6:02 pm
Hey guys
thnx for the info...wel the reason why i dont have the reg is that if its not shown in the photo i probably dont know  Smile Im just 18 and i only take the photos, and dont keep a log...ill offcourse do my best to get the reg. For the UA772 i got the reg and re-upload...I will put the Delta in the Appeal or should i re-upload? appeal right?
thanks for the info guys real great help Big grin
cheers!
Nick
btw today is my 4th year as memeber at a.net Big grin ahah i was 14 when i joined :P
cheers
Users browsing this forum: Bing [Bot] and 1 guest
