QantasA332
Before I Upload - Is This Level?
Fri Oct 22, 2004 11:55 am
Before I upload this photo (highly compressed for Photobucket)...
...does it look level to you? I think it somehow doesn't look right, but I checked with a grid and it seems okay. Your opinion? Also, anything else that might need changing?
Thanks in advance!
QantasA332
JeffM
RE: Before I Upload - Is This Level?
Fri Oct 22, 2004 12:09 pm
It is a small photo to "eyeball", but from what I can see, it looks like the tower is leaning to the left. It looks a bit dark as well.
bigphilnyc
Fri Oct 22, 2004 12:13 pm
Yeah, it's tough to tell for sure because of it's size. For a definite answer, I recommend you link us to a full-size version of the shot.
I think the ground is tilted, and that gives the illusion of the tower being crooked too. Again, it's small, so I'm not sure, but it actually looks level to me.
-Phil
Phil Derner Jr.
twr75
Fri Oct 22, 2004 12:20 pm
Do you have Photoshop? If so, use the ruler tool to run a line along what you want vertical (or horizontal). Then use the abitrary rotate canvas command and the angle required to rotate will be automatically entered.
Like a seagull on the MCG of life...
QantasA332
Fri Oct 22, 2004 12:32 pm
Sorry about the size, here's a bigger one (with quality greatly reduced):
http://photobucket.com/albums/v167/gpks90/?action=view¤t=test.jpg
I always start with that when rotating, but it's still often hard to get it exactly right. Thanks for the suggestion anyway!
QantasA332
QantasA332
Fri Oct 22, 2004 2:10 pm
Argh! Sorry about the confusion, here's one you can access:
http://img.photobucket.com/albums/v167/gpks90/test.jpg
QantasA332
cboyes
Fri Oct 22, 2004 2:19 pm
QantasA332
It does look as though the tower is leaning a bit to the left. I haven't used a grid on it, this is just the impression I get looking at it.
Craig B
PNEPilot
Fri Oct 22, 2004 2:22 pm
using the yellow runway edge marks and the yellow framework on the tower I'd say it needs a degree or so CW to my eyes.
clickhappy
Fri Oct 22, 2004 2:23 pm
looks good to me.
OD720
Fri Oct 22, 2004 3:01 pm
Looks okay to me too.
QantasA332
Fri Oct 22, 2004 3:04 pm
Thanks for the suggestions, everyone, I've decided to upload it as is. Hey, if a screener says it looks good, you can't go far wrong can you?  Big grin
QantasA332
lyzzard
Fri Oct 22, 2004 3:22 pm
There's just a slightest hint of tilt to the left. A 0.2 or 0.3 degree right tilt should do it.
QantasA332
Mon Oct 25, 2004 6:51 pm
I guess listening to a screener wasn't the best idea in the end - the photo was just rejected for badangle.  Sad
Let's try again. Here's the photo:
http://www.airliners.net/procphotos/rejphoto.main?filename=qantas_737_vhtjt_211004_G_edited.jpg
Tilting left? 0.2-0.3 degrees CW should do it? Thanks in advance for the additional input.
QantasA332
(If you wouldn't mind, the following photo also got rejected for badangle - what would fix this one? http://www.airliners.net/procphotos/rejphoto.main?filename=airfrance_boeing_fgsqf_n50217_211004_G_4_edited.jpg)
draigonair
Mon Oct 25, 2004 7:06 pm
Hey QantasA332
that airfrance is almost straight but i guess a little CCW...but its VERY minimal...
that Qantas one needs a little CW, bit more thant the Airfrance
good luck!
cheers
Nick
cheers
SA006
Tue Oct 26, 2004 1:24 am
I like your QF pic..VERY NICE!!  Big thumbs up
About the AF...seems a little dark?
SA006
Proudly South African
TZ
Tue Oct 26, 2004 5:21 am
The (revised) Qantas is still leaning CCW - needs a little CW rotation. Just look at the yellow bits of the tower structure, and the side of the glassed area at the top.
The AF also needs CW rotation. Just resize your IE window and line the edge of the window up with the lamp posts. They all lean CCW. It should also have been (or maybe it was and you didn't mention it) for badborders (bottom-left).
Tamsin (a.net screening crew)
TZ Aviation - Aeropuerto de los Banditos Team Images
QantasA332
Tue Oct 26, 2004 6:04 am
Thanks for the tips everyone (and the very kind compliment, SA006)! Below is a revised version, heavily compressed for Photobucket:
http://img.photobucket.com/albums/v167/gpks90/test2.jpg
Good? Better? I checked with a grid and it seemed okay...
Dunno how I didn't catch that...oops! Embarrassment
QantasA332
TZ
Tue Oct 26, 2004 7:16 am
The Quantas looks good to me now.
Please don't ask us to level ALL your shots before uploading them!  Smile/happy/getting dizzy
QantasA332
Tue Oct 26, 2004 7:31 am
Of course I won't! It was just this one that I wasn't too sure about...
Thanks for the help!
QantasA332
