DLKAPA
Ok Screeners, I Really Don't Agree
Thu Oct 28, 2004 2:14 pm
So if somebody could help me out on seeing something that i'm not, that would be great.
BadQuality:
http://www.airliners.net/procphotos/rejphoto.main?filename=N903TArampAPA.jpg
http://www.airliners.net/procphotos/rejphoto.main?filename=N816SQRampFrontOnAPA.jpg
http://www.airliners.net/procphotos/rejphoto.main?filename=N780ErampAPA.jpg
BadMotiv:
http://www.airliners.net/procphotos/rejphoto.main?filename=N808WEngineRampAPA.jpg
http://www.airliners.net/procphotos/rejphoto.main?filename=N101PNrampAPAjetpreview.jpg
BadQualityBadExposure
http://www.airliners.net/procphotos/rejphoto.main?filename=N373XPCockpit.jpg
Someone please help me, If these seriously are badquality I think my eyes are starting to go on me. But if they are badquality/badmotiv/badeveryotherreasonilisted, please help me maybe fix them?
JeffM
RE: Ok Screeners, I Really Don't Agree
Thu Oct 28, 2004 2:36 pm
1. overexposed and grainy feeling. (bad time of day)
2. same
3. same
(could be bad processing that caused this?)
4. Too much space on the right, and "badfueltruck" (obvious)
5. My eye wanders the photo... engine? or people? engine? or people? engine? or people?
6. Definitely "badexposure". The ray of light and the windscreen tricked your exposure. You are not showing both yokes which you could have if you took this in landscape mode versus portrait mode. There are reflections on the instrument panel. Lots of soft stuff that should be in focus on the pedestal. It has that grainy feeling too. If you had exposed for the outside then used some fill flash it might have helped, but at that time of day it would be "iffy".
It is a fun show, but it's not suited to photography.
DLKAPA
Thu Oct 28, 2004 2:42 pm
Jeff,
Wow, when I opened this thread I expected a verbal assault  Big grin
Anyway, Thanks. I might be able to improve the first three grain-wise, and I Think if I crop the engine in no. 5 then It might help my motiv purposes.
JeffM
Thu Oct 28, 2004 2:46 pm
It's not your fault. Shooting at that time of day is almost not worth the time. I've been a few times and have many that have the same symptoms.
draigonair
Thu Oct 28, 2004 6:00 pm
You can maybe makethe photo of the tail smaller...so you can see the whole pic and not 'look' around...and maybe crop abit!
goodluck
Nick
cheers
kc7mmi
Thu Oct 28, 2004 6:04 pm
Sure the light is bad, but those are some good photos. No reason to reject 'em...especially the first 3.
sulman
Thu Oct 28, 2004 6:10 pm
Eric,
I like these. With the exception of the cockpit shot, and the engine/people shot, I think every one of those could be rescued. The badquality rejections are only marginally so; I'd be definitely tempted to spend some time working on them.
My first thought when I looked at the first three was "Bloody hell, it looks hot there!". The sunlight looks almost overwhelming, but I reckon the exposure is okay on the first three. Have a play with the tone curves or shadow/highlight tools. Try and bring out some more contrast in the picture - slightly richer blue to the sky etc.
It looks like you've got that light that washes out edges ever so slightly, which means that USM doesn't work so well. I think that might cause you problems on 2 & 3 (of the first set).
I think with a bit of cropping,
Could be absolutely mega!
James
lyzzard
Thu Oct 28, 2004 6:51 pm
1. N903TA - Was this shot through glass? I thought I could see some reflections in the ground area.
3. N780E - Levelling looks a little off to me. Needs a bit of left tilt.
The cockpit shot does look over exposed. You should meter with the light outside the window and fill the cockpit with a flash. That way both inside and outside are properly exposed.
Ejazz
Thu Oct 28, 2004 7:28 pm
Hi Eric
As I get older my eyesight is supposed to be heading down the toilet so I'm surprised no-one has mentioned all the dust spots in the first three shots which may explain the bad quality rejection. The first two shots in particular have a lot.
The good news is I think N808WEngineRamp is terrific. BadMotiv is always a tough reason for a rejection but life goes on.
All the best
Bailey
Etihad Girl, You're a great way to fly.
SA006
Thu Oct 28, 2004 7:53 pm
Maybe sharpen the first 3 a little?
Very nice shots and , as Sulman said , that engine shot is awsome!
Good luck  Big thumbs up
SA006
Proudly South African
Users browsing this forum: No registered users and 18 guests
