sleekjet
Changing Data In A Database Photo
Wed Nov 03, 2004 8:33 am
I know I've seen this discussed here before, but I can't recall the answer. I want to change the comments in a couple of my database photos. Is it possible? If so, what is the procedure?
II Cor. 4:17-18
clickhappy
RE: Changing Data In A Database Photo
Wed Nov 03, 2004 8:40 am
Sleekjet.
Have a go over to http://www.airliners.net/about/ And you will see contact info for the database editiors. They should be able to get your sorted.
QantasA332
Wed Nov 03, 2004 9:12 am
I've gone through the process myself, and rather than emailing a database editor it's just as easy to edit the remarks through the "sumbit correction" interface for each photo...
QantasA332
Jaspike
Thu Nov 04, 2004 12:53 am
Yep, just submit the correction with the email address you use when uploading photos, and you'll get priority treatment  Smile
Tom
SnowJ
Thu Nov 04, 2004 9:18 am
Just as QantasA332 and Jaspike said, if you just select "correct info" on your photo, change what you want changed and cite the reason for change in the appropriate block, they'll happily accommodate the change. I've done it to a few of my photos myself. They're really good about that.
I have a really bad habit of reiterating what people have already said...sorry guys.  Big grin
Jaysen F. Snow - Midwest Tail Chasers
