PNEPilot
Quick Question For Digital Rebel Owners
Thu Nov 04, 2004 6:02 am
A little off topic, I'm afraid, for which I apologise, however I don't know anywhere else I can find a bunch of Digital Rebel owners to answer mu question:
Is the battery charger that comes with the Digital Rebel universal or 110volt? In other words, will I be able to use it to charge the battery on my trips to Europe and other places with 220/240v AC supplies?
Thanks in advance.
TZ
RE: Quick Question For Digital Rebel Owners
Thu Nov 04, 2004 6:04 am
Are you sure it doesn't tell you on the certification sticker on the charger itself?
My European one carries just such a sticker which indicates that it will work in both 220/240 and 100v supplies. I can confirm it has always worked throughout Europe and USA.
Tamsin (a.net screening crew)
TZ Aviation - Aeropuerto de los Banditos Team Images
mikephotos
Thu Nov 04, 2004 6:10 am
PNEPilot,
You can find a bunch of 300D/Drebel owners here:
http://forums.dpreview.com/forums/forum.asp?forum=1031
Mike
PNEPilot
Thu Nov 04, 2004 6:11 am
I don't have a Digital Rebel to check the sticker - that's the reason I am asking.
My sister is thinking of taking advantage of lower US prices and strong pound/dollar exchange rate to buy one to take home to England when she visits later this month...
We know all about the inherent possible problems with warranty and such like, but want to make sure we take all factors in to consideration: if she has to spend another GBP50 or more on a battery charger then it probably isn't worth it.
JohnJ
Thu Nov 04, 2004 6:16 am
I used my US-purchased Rebel charger in London without incident, using only a wall socket adapter.
DC9
Thu Nov 04, 2004 6:30 am
It works without any problem whatsoever.
A319114
Thu Nov 04, 2004 7:51 am
As it says on the charger itself:
Input: 100-240 V AC50/60Hz, 22 VA(100V)-30VA(240V)
You should be fine  Smile/happy/getting dizzy
Destruction leads to a very rough road but it also breeds creation
PNEPilot
Thu Nov 04, 2004 7:57 am
Thanks everyone. Your help is appreciated.
Users browsing this forum: Virginblue4 and 1 guest
