FlyingColors
Nikkor 80-400MM Trouble/help!
Mon Nov 08, 2004 12:32 pm
Problem:
My D100 shows a displayed shooting error of "F EE". Shutter will not release.
I have confirmed the minimum aperture is set and the lens is seated to the body.
In field diagnose includes removing and replacing the: card, battery and lens. Powering off and on several times too. Swapping the card and battery with spares.
ONLY after either installing a different lens OR reinstalling the 80-400 about 25 times does the problem fix itself until whenever, at the worst time.
Have checked all pin connections in the camera and the lens. Cleaned the above mentioned contacts too. Note the mounting surface to lens has zero play/wear.
Please help!!
FC
Moon chaser!
kc7mmi
RE: Nikkor 80-400MM Trouble/help!
Mon Nov 08, 2004 3:32 pm
Does that lens have an apperture ring on it? If so, make sure it is at the smallest apperture (usually marked in orange) and make sure it is locked there. If it is other than the highest apperture setting, you will get FEE.
ChrisH
Mon Nov 08, 2004 6:17 pm
he said minimum aperture was set
try cleaning the contacts, if that doesnt help, it sounds like its time for service
what seems to be the officer, problem?
codeshare
Tue Nov 09, 2004 1:43 am
Since the lens is a CPU type, maybe something went wrong with it?
Did you contact your Nikon dealer or service ?
How much A is there is Airliners Net ? 0 or nothing ?
sunilgupta
Tue Nov 09, 2004 12:51 pm
If you have a friend that has a Nikon body (a newer one) throw the lens on that one. All it will tell you is that it's the lens for sure before you send it out for service.
If you do have to send it out, send it to the NY service center. Include a cover letter, the warranty card, a copy of your bill and a copy of the 5yr extension certificate (if your lens came with it). They performed a miracle on my lens and didn't charge me a dime.
Sunil
Nikon Inc. Photo & Digital Service
Nikon Inc. Factory Service
1300 Walt Whitman Rd.
Melville, NY 11747
kc7mmi
Tue Nov 09, 2004 3:07 pm
FC, just be sure that's Nikon's address and not Sunil's  Laugh out loud
