philhyde
Rejection Advice: Badqualitybadsize
Thu Nov 18, 2004 5:28 am
Hi,
I'm not very new to airliners.net, but I have recently begun taking pictures after purchasing a Canon Powershot Pro1 last month. Since then I've been reading the posts here and taking the recommendation to only upload a few pictures at first to get feedback. Since my first submission earlier this month I've had 4 rejections. I have one re-done photo in the ready queue.
The most recent rejection was Air Canada Jazz C-FDJA (new a/c) for 'badqualitybadsize'. Here is the picture I uploaded:
http://www60.pair.com/philhyde/aviation/20041113/IMG_0012.JPG
After reading the feedback (curiously linked on the appeal page), I can see now that the size of the photo was probably the major objection. Initially I had some difficulty avoiding some ramp clutter very close to the top of the photo. I have since been successful at re-cropping the photo to 1152x723, which is much closer to 3:2 than the original 1152x619. Here is a small version of the raw photo:
http://www60.pair.com/philhyde/aviation/20041113/small/IMG_0012.JPG
I've re-worked the photo by sharpening the front area, and also adjusted the colors to look not so faded. The sky was overcast and everything looked really drab. Here is my re-worked photo, and I'd appreciate any feedback.
http://www60.pair.com/philhyde/aviation/20041113/jazz_cfdja_iah20041113.jpg
Thank you!
Phil
Canon junkie - Aviation Nut
mikephotos
RE: Rejection Advice: Badqualitybadsize
Thu Nov 18, 2004 6:14 am
Just to make it easier on folks that want to check-out the links:
Edit: Just to add my comments on the new "reworked" image. The crop is certainly better but the nose and winglets seem to be a bit soft. Also, as many others recommend, try uploading it at 1024x??? instead of the larger size.
Mike
[Edited 2004-11-17 22:19:37]
philhyde
Thu Nov 18, 2004 10:14 am
Here is a quick resize at 1024 and some sharpening.
http://www60.pair.com/philhyde/aviation/20041113/jazz_cfdja_iah20041113_3.jpg
clickhappy
Thu Nov 18, 2004 11:16 am
the problem with the photo is that the tail section is sharp, but the nose is slightly out of focus, causing it to be soft.
philhyde
Fri Nov 19, 2004 4:12 am
In this photo, I sharpened up the front of the a/c - does it look better?
http://www60.pair.com/philhyde/aviation/20041113/jazz_cfdja_iah20041113_4.jpg
With regard to the nose being out of focus, it also seems like there is little visible distinction between the nose and the ground. Alas, this is because of the poor light.
