Psych
Advice On Cropping Please
Fri Nov 19, 2004 4:26 pm
I am very keen to understand more fully the criteria used by screeners for photo acceptance, so here goes with another question for you guys out there.
I have put this photo in the queue - partly in order to be able to provide a link for it, which I have now learned how to do.
http://airliners.net/addphotos/big/ready/GWWBM1311.jpg
If I were a screener I myself think that there may be problems with this one due to the cropping. I recognise that this is a very frequently photographed aircraft, and for this reason alone new photos accepted will have to be 'different' or exceptional in some way. According to my own view, I think I have scored points on the 'different' criterion - I do like the contrast between the bright red elevators and the blue colour scheme. However, I am not happy with the cropping, but this is the best I think I can do given what I have with the original (there is not that much more of the original outside this crop).
I am frustrated with myself for not having zoomed out a bit more at the time, but it is as it is. Basically I am worried that the lack of a complete nacelle on the left, together with only half the undercarriage in view, will cause this to be rejected. Though the elevators are 'balanced' in the photo, I am also concerned that the relative lack of balance in other areas - i.e. space to the right of the engine on the right, but the left being cut off - would be a fatal flaw.
I would value comments to help my education, as I am not keen to waste screener's time, or increase my already healthy ratio of rejections.
Still learning a lot.
Thanks.
Paul
Tin67
RE: Advice On Cropping Please
Fri Nov 19, 2004 5:07 pm
Paul,
It's spot on in terms of colour and clarity, I really like that fact that the elevators are being tested as it really adds colour to the shot. But...
As you say above the zoom factor is too much. It may well be rejected for badmotiv as the undercarriage and starboard engine are not included in the full frame. Pity it's a really nice shot otherwise.
I'm sure you'll get another opportunity to get a shot like this. I'm always having to do this, try try again. You'll nail it next time.
Martin  Smile
Psych
Sun Nov 21, 2004 6:14 pm
Thanks Martin. Unfortunately the photo had been rejected before any further debate could be had. So the original link has now gone. The new link is:
http://www.airliners.net/addphotos/rejections/big/GWWBM1311.jpg
Although I cannot argue with a rejection I am still interested to hear whether anyone can think of a way this photo could be cropped differently, and potentially saved. Or is the lesson that if certain elements of a photo are cropped/not complete then it will always fall foul of the screening process, whatever else is happening in the photo?
Paul
P.S. As previously, no sour grapes here - just looking for further clarification.
aviopic
Mon Nov 22, 2004 1:41 am
Is this the original Paul or did you crop it your self already ?
I like the pic. though it really needs another crop which would not be a problem if you had a few pixels more to offer.
Willem
The truth lives in one’s mind, it doesn’t really exist
INNflight
Mon Nov 22, 2004 1:44 am
Sorry to say, but the shot just does not look right without the whole gear in frame. Qualitywise it's very good.
Don't zoom that much next time, it's a nice motive!
Florian
Jet Visuals
European
Mon Nov 22, 2004 2:00 am
I like the picture bit as INNflight said
I would not have zoomed in as much
and...
I would like to have seen the Gear!
Good luck though in the future. I am having problems too with the whole cropping and editing thing.
European
Come on Ryanair! Come on BOH! BASE BASE BASE! Flying high in the skies...........
mirage
Mon Nov 22, 2004 2:07 am
Like Florian said, without the complete gear I think it's a lost case but in case you had it, I would crop this way:
To me, it looks more balanced.
Or in case your original is big enough like for example 3072px and in case the quality keeps good, I would also think about this way:
It removes lots of empty space (the sky).
Luis
Psych
Mon Nov 22, 2004 3:40 am
Thanks Fellas. Unfortunately the original does not have the complete gear, though what you see is cropped slightly. Basically I have to admit I messed up with this. It was one of those situations where I had about a second and I was so focused on catching the elevators and not messing that part of the photo up that I forgot to think about the gear (and the other engine nacelle). Good learning experience though. However, I wish I was as optimistic as Martin in his earlier response about their being another similar opportunity - this happening near the holding point, in good light (at Manchester) and me being there at the same time - I'm not so sure!
But I do like Luis' latest offering. They definitely look more balanced. The original is 3072 x 2048, so that second close in crop would be viable - if the lack of complete gear would not still negate the chances of acceptance.
Any other (screeners') views on that? And thanks to Luis for taking the time to mess with the image.
Paul
Jofa
Mon Nov 22, 2004 3:46 am
Why not tilt the camera 90 degrees the next time?
tracon
Wed Nov 24, 2004 7:35 pm
Try to get as centered as possible, and take Multiple shots adjusting the focal length each time. Your motive is great, but the angle isn't  Sad
Overall good, though. Also, that 3rd crop looks a lot better than the first.
Keep up the good work
-Tracon
Psych
Thu Nov 25, 2004 5:54 pm
Firstly, thanks to all for your helpful comments so far. I have a couple of things to add:
I am still keen to salvage something from this image if at all possible - especially as, with the weather like it is today, it is almost impossible to imagine Manchester in the sunshine again! But this kind of debate is also helping my general education on these matters. I have recropped the original image - close in, rather similar to Luis' 2nd cropping suggestion, but losing all the gear. Unfortunately I cannot work out how to post that image with this thread without making a new link to a resubmission (or a link to some other web space) - so how did you do that Luis? I want to get further feedback here before uploading another image likely to be rejected.
Also, when I look at my new cropped image, even though it still shows off the bright red elevators nicely (and the contrast with the blue of the fuselage is basically the motive for this shot), I become concerned that it resembles too closely another image that I already have on the database (see below).
Photo © Paul Markman
However, this photo is of G-WWBB, whereas the crop we are referring to is another airframe, G-WWBM. Therefore I would also be grateful for your comments as to whether the obvious similarity between the 2 images would mean that it would be likely to be the cause of a rejection, irrespective of whether the screener thought the new cropping was acceptable. Or, as they are different airframes, does any similarity becomes irrelevant. Or, finally, should I just give up and put it down to experience?
Clear as mud? I hope so.
Paul
Psych
Sat Nov 27, 2004 1:33 am
I have plucked up the courage to give this another go - in the absence of any further feedback - and it is now in the queue again. If anyone is interested it now looks like this:
http://www.airliners.net/addphotos/big/ready/GWWBM1311.jpg
I would still value any comments, especially relating to the similarity with the other BMI 330 photo, prior to this image getting to the front of the queue. If I am refusing to accept defeat and can't see that do let me know. My rejection rate is improving, but too 'healthy' for my liking, and so I am keen to avoid another one if it is obvious to others.
Thanks again.
Paul
European
Sun Nov 28, 2004 2:17 am
Psych,
Good luck - it would be nice to see it on a.net - The red flaps look great so it may get up-loaded!
European
Jimmi
Psych
Mon Nov 29, 2004 4:54 pm
A brief thank you to all of you who have given me feedback on this one. Some wonderful screener has allowed it on to the database. A special thanks to Luis for his efforts.
Paul
European
Fri Dec 10, 2004 2:13 am
I saw it on the databass a few day's ago,
Well done!
European
Jimmi
Psych
Fri Dec 10, 2004 7:09 am
Thanks for that Jimmi.
Paul
