Danny
Sigma 1.4x Converter With Rebel
Mon Nov 29, 2004 2:52 pm
Does anyone use this converter with sigma 70-200 and Rebel? Could you share your opinion? I've heard that there may be some problems. The question is to buy or not to buy.
thanks
Daniel
vir380
RE: Sigma 1.4x Converter With Rebel
Mon Nov 29, 2004 3:08 pm
I used the 1.4x with the 70-200 f2.8 albeit with a Canon D60 with no problems whatsoever !
it still remains auto focus and pin sharp , with no visible loss of quality at all , and the lens then runs at F4
hope that helps
Tony
[Edited 2004-11-29 07:08:38]
Moved away from this lost website to better things !
ua935
Mon Nov 29, 2004 5:04 pm
Hi Daniel,
Do a search on my name in the photos section, Simon Gregory.
I have a number of shots uploaded using the 70-200 F2.8 EX HSM and the 1.4x EX converter. I am very happy with the results.
Regards Simon
Live every second like you mean it
Sukhoi
Mon Nov 29, 2004 7:00 pm
1.4 works fine on the 70-200 2.0 is crap though very soft at the longer reaches so beware.
Paul
aviopic
Tue Nov 30, 2004 4:21 am
They both work fine Daniel, even stacked on top of each other.
Don't know where Paul's statement is coming from but it might because he is using Nikon and i have seen earlier topics where Nikon users were not happy with the Sigma combo.
On your Canon though it is absolutely no problem at all although i would not try a Canon 70-200 on a Sigma tc and v.v.
Here are some examples for which i used a Sigma 70-200/2.8 EX(hsm) combined with a 2.0 tc.
Data: Hunter 293mm, 1/1000s, F7.1
Data: Spit 350mm, 1/800s, F6.3
Photo © Willem Honders
And 2 at maximum range.
Data: Pilat 400mm, 1/400s, F7.1
Data: Connie 400mm, 1/640s, F7.1
Good luck,
Willem
The truth lives in one’s mind, it doesn’t really exist
clickhappy
Tue Nov 30, 2004 6:39 am
Willem, those are great examples of the 2.0 and the 70-200 EX.
You def. want to stop it down a bit, the 2.0 gets a little soft wide open (5.6)
aviopic
Tue Nov 30, 2004 7:08 am
Yes that's true HappyClick  Smile/happy/getting dizzy, a wide open lens will always be a tad softer then a stopped down one.
Far from unworkable though.
This example is wide open and maximum range.
Data: 400mm, 1/1000s, F5.6
Watch the girl in the back smiling at me, never understood why this was rejected Big grin
Data: 293mm, 1/800s, F5.6
sleekjet
Tue Nov 30, 2004 10:42 am
I've had no problem plugging in a Sigma 1.4x between my 300D and 70-200 f/4 L. Here's an example: (please, no cheap hits)
Photo © Tim Perkins
II Cor. 4:17-18
Users browsing this forum: jboy8899 and 1 guest
