A346Dude
Canon D30 Vs. D60
Fri Dec 03, 2004 12:03 pm
I am currently in the process of deciding what camera I should buy to replace my 2MP point-and-shoot. I have pretty much decided that I want a DSLR.
So, the question is, which should I get. Since I am a student, I am on a bit of a budget, so I figure the 300D would be the most expensive camera I would consider.
What I'm wondering is: how good are the Canon D30 and D60? How is the image quality of these cameras in comparison to more recent ones. Which of the two would you recommend? And finally, are these cameras reliable if they are a little older as I would be purhasing a used one?
Thanks for the help.
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
A346Dude
RE: Canon D30 Vs. D60
Fri Dec 03, 2004 1:10 pm
Sorry, I am unable for some reason to edit my original post...
One last question: where is a good place to buy used DSLR cameras?
Thanks again.
vaman
Fri Dec 03, 2004 2:28 pm
I use the D30, and if you know it's limitations, it is a great price for your first DSLR. A D60 is fantastic as well. I suggest you search the photodatabase for D30 or D60 in the remark field, and you can look at my photos under Logan Anderson.
L
wietse
Fri Dec 03, 2004 4:03 pm
For the D60, do a search for Wietse de Graaf.
They could just as well have been taken with the D30 though, you arent going to tell from A.net size images. But the D60 is a bit more complex and advanced though.
I would get a D60 over a 300D anytime.
Wietse
Wietse de Graaf
UTA_flyinghigh
Fri Dec 03, 2004 5:28 pm
It isn't. The D60 is simply the D30 with a 6MP sensor and minor cosmetic differences.
There's the same 3-point AF taken from the EOS 50 (very old camera).
It all depends on your needs. If you need a large buffer, the D30/D60 are superior. If you need really fast AF then go for the 300D.
Need both ? Find a cheap used 10D Big grin
Will
Fly to live, live to fly - Air France/KLM Flying Blue Platinum, BMI Diamond Club Gold, Emirates Skywards
ckw
Fri Dec 03, 2004 6:23 pm
Well, I had a D30 and quickly replaced it with a D60 - although essentially the same camera in many respects, as well as the large sensor Canon made a number of improvements to the software. While it does use basically the same AF system, the accuracy and responsiveness was much improved (though they didn't really get this right until the 20D) and file writing/buffering were enhanced. Net result is that the D60 is a more effective camera.
However, these cameras are over 2 years old, and the shutter is rated at 30K actuations. Many of the used examples will have exceeded that (doesn't mean the shutter is about to fail ... but it might). I would think that a new 300D would run cheaper than the cost of a D30/D60 plus a shutter replacement within, say 12 months.
But if you can source a used D60 which has been lightly used (be careful, the frame count accessible by the user can be reset!) it could be a very good buy.
Colin
Colin K. Work, Pixstel
wietse
Fri Dec 03, 2004 8:10 pm
300D AF is not that much faster than the D60 AF. I'd put them in the same category. And with the AI focus available in all modes, I would rate the D60 higher, AF wise.
Wietse de Graaf
UTA_flyinghigh
Fri Dec 03, 2004 8:25 pm
It trounces it you mean  Big grin
There is no comparison between the fast 7-point AF of the 300D/10D whch comes from the EOS 30/33 and the old 3-pont AF on the D30/D60 which comes from the old EOS 50.
French mag Chasseur d'Images conducted an AF test using the 70/200 f/2.8L on the D60, the 300D, the 10D and 20D.
http://www2.photim.com/info/Sommaire.php
The D60 got easily trounced and showed its age compared to the more recent models .
Will
wietse
Fri Dec 03, 2004 9:22 pm
As said, these two cannot be compared. And what would you rather have, full compatibility with ALL focus modes, or just a really fast static one? What is the point in having fast autofocus if the subject is static anyhow?
Wietse de Graaf
UTA_flyinghigh
Fri Dec 03, 2004 9:29 pm
I fully agree with you on that. With static subjects I don't even take the 20D out - the G5 works just fine.
Both LOL  Big grin
Will
AdamWright
Fri Dec 03, 2004 11:18 pm
Hey,
Glad you are considering the Canon line of DSLR's.
As for a bout between the D30 and D60, I would take the D60 any day. I almost purchased a D60 but went for the 300D as it came with a 1 year warrenty.
I bought my 300D from eBay and was very pleased. But, I know many users of the D60 and who have had the D60 for many years and still get stunning photos from the camera. It's built to last. And thats important in a Camera. Especially to one who is new to holding such a large camera. The 300D has plastic casing. While this doenst affect the image, it is a factor when you might bang the camera while holding it by the straps, etc. The hard casing (magnesium?) of the D60 is like a warrenty in itself.
The D30 takes a good picture, don't get me wrong. But there is a reason people upgrade. Teh D60 has better ISO functioning (Allowing you to shoot in lower light) and offers 6.3mp vs. the D30's 3.2mp. This just means you'll be able to crop your shots a little tighter.
Good luck with your quest for the DSLR.
-Adam
