JAT74L
And Now For Something Normal Again. Badangle Help!
Mon Dec 13, 2004 6:10 am
I like trains just as much as planes but trains don't like the Atlantic!
wietse
RE: And Now For Something Normal Again. Badangle Help!
Mon Dec 13, 2004 6:15 am
Use the two main wheel axles to level the image. Plus, there is weird sharpening stuff going on.
Wietse de Graaf
aviopic
Mon Dec 13, 2004 6:16 am
It appears to be not level John.
Look at the mast in the back ground, that should be vertical.
I would say it is about 2 degrees off.
Willem
The truth lives in one’s mind, it doesn’t really exist
jumbojim747
Mon Dec 13, 2004 6:18 am
To me it looks like the left side of the picture is lower then the right side measure from the landing gear to the bottom of the picture on both sides and you can tell the difference.
But maybe a screener can tell you more .
Can anyone suggest a good way to line a picture up as sometimes cropping doesn't help much.?
On a wing and a prayer
aviopic
Hee you beat me Wietse  Laugh out loud
But i have to disagree with you, it appears that the runway is sloping too therefore the axle can't be used as reference.
Willem
aviopic
Mon Dec 13, 2004 6:22 am
If possible always take a fixed reference point from which you know it is supposed to be level or straight up, like a light mast or something.
Runways are usually not level as you want the rain water to flow sideways.
jumbojim747
Mon Dec 13, 2004 6:33 am
Aviopic
Is there anyway we can rotate the image to be level Before cropping
I tried to crop a few times but it only crops the picture but leaves the angle the same any help would be appreciated.
jid
Mon Dec 13, 2004 6:37 am
About 1.1 degrees CW levels it up in my view. If you use the ILS radiator on the left, this should always give you a correct vertical reference.
Jid
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
javibi
Mon Dec 13, 2004 6:42 am
JumboJim747:
This thread (if it hasn't been deleted)  Wink/being sarcastic might help:
http://www.airliners.net/discussions/aviation_photography/read.main/76567/6/
Saludos
j
P.S: Edited to make the link work
[Edited 2004-12-12 22:44:29]
jumbojim747
Mon Dec 13, 2004 6:55 am
Javibi
Got it thanks a lot javibi .
Im new to the game and learning a lot with the help of everyone on here .
A great bunch of people.
Psych
Mon Dec 13, 2004 7:35 am
Hi John,
I'm with Jid on this one. I also make it about a 1 degree rotation clockwise.
I have learned from many badcamerangle rejections that you must use anything in the image that could be seen to be reliably vertical - in this case that ILS radiator/aerial (or whatever it is) on the left is good. In the photo as it stands it is definitely leaning a bit to the left. Personally I would ignore the plane itself or the taxiway, as they can be far from level.
I have more recently tended to put a note to the screeners telling them what I have used to ensure the camera is level. Fluke or otherwise - since doing so I have had no rejections for this. (But I won't hold my breath).
Take care.
Paul
mattbna
Mon Dec 13, 2004 8:08 am
I thought we had all decided in here quite some time back that light poles are not a good source of level/vertical?
I wish there were a good building vertical that he could use in that photo as most of those radio towers aren't exactly level either.
I'll go with wheel axles on this one as they should be right across from each other. On that note, I guess you could also use the spinners in the engines...
Matt
Canon EOS 7D & 40D -- 100-400mm L IS -- 70-200mm f/2.8L IS II -- 28-135mm IS -- 10-22mm -- 18-55mm EF-S
Kereru
Mon Dec 13, 2004 11:34 am
Just rotated 0.7 cw and looks fine now to me? Even that tower looks vertical?
I use a vertical and or a horizon line to get photos level. Airport runways are not always level as they have to drain when wet and I always add a note to screeners in this case. It does Help!
Good things take Time.
Users browsing this forum: No registered users and 4 guests
