airkas1
Crew
Help Needed With Rejections Please
Tue Jan 18, 2005 8:53 pm
Hey all,
I had uploaded 13 shots of which I thought looked very nice. I was anxious to find out how they did, so I looked forward to the e-mail this morning.
But when I opened it, I was baffled to see all 13 were rejected, most of them with a reason a had never gotten before: baddirty.
I also came across 2x badpersonal. They screener mentioned dust spots in the e-mail, so I guess dustspots warrant a badpersonal rejection?
I understand why those 2 shots were rejected.
But there were 9 baddirty and 1 was badquality (with 1 badqualitybadcommon and 2x badpersonalbaddirty). I tried to find the page on which all the rejection reasons are explained, but I couldn't find it.
These are the shots in question:
Baddirty:
http://www.airliners.net/addphotos/rejections/big/KL_772_PH-BQE_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/KL_763_PH-BZC_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/CO_772_PM_N77014_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/Olympus_737_SX-BKF_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/NW_330_N808NW_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/KL_MD11_PH-KCB_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/KL_772_PH-BQG_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/Maersk_737_OY-MRK_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/U2_737_G-IGOU_15-01-05kj.jpg
Most of the baddirty shots were rejected for this reason and nothing else.
Badquality:
http://www.airliners.net/addphotos/rejections/big/BA_321_G-EUXD_15-01-05kj.jpg
This was one of my favorites:-(
Dustspots:
http://www.airliners.net/addphotos/rejections/big/NW_D10_N232NW_15-01-05kj.jpg
Above the first tail
http://www.airliners.net/addphotos/rejections/big/MP_763_NC_15-01-05kj.jpg
Vaguely above the nose
Can anyone please explain the "baddirty", because I don't know. Also, can I save these images and how do I get rid of dust spots? I really hope I can fix them.
Kas
(Somehow I couldn't get the non-clickable links to work)
Airliners.net Crew - Head Photo Screener
INNflight
RE: Help Needed With Rejections Please
Tue Jan 18, 2005 9:36 pm
(Bad)personal just tells you that you got a personal message from a screener at the bottom of the email - This has nothing to do with the quality / motive etc.. of the photos itself. It only tells you the screener wrote you a personal message.
Jet Visuals
dendrobatid
Tue Jan 18, 2005 9:55 pm
You have dirt on your sensor.
Look above the unfortunate light on the nose of Max and there is a dark mark. If you reduce the brightness a bit it will hit you. That was the only one I could see
Very fixable using the clone tool
Mick Bajcar
LHSebi
Tue Jan 18, 2005 9:56 pm
Hi Kas,
About the baddirty rejections...I didn't look at all of them, but most of them seem to have one main dustspot towards the top-left of the picture. If you open the Peter Max picture, extend upwards from the light post on the right, and you will see the spot. It sometimes helps to make the window in which you opened the picture non-maximised, and then move the whole window in circles, or from side-to-side. This will make any dark (dust) spots stand out as they will also move around with the picture!
The badquality BA shot is very nice, but I notice 2 things. 1) The plane is extremely oversharpened. This is visible especially around the area where the blue meets the white part of the livery. There are jaggies everywhere. 2) Is it possible that you used neatimage? The sky has a pastel-like look.
Re the dust spots, you can try to remove them using the band-aid tool in PS. It does a very good job in fixing up pictures. However, be wary of badmanipulation rejections, which you may get if you don't do it subtle enough  Smile.
As for the clickable links: the reason is that there are those abbreviations that give a tool-tip thing for the airport/airline. The solution is to make those letters lowercase, as the filenames are not case sensitive, but the tool-tips are!
http://www.airliners.net/addphotos/rejections/big/u2_737_G-IGOU_15-01-05kj.jpg
http://www.airliners.net/addphotos/rejections/big/MP_763_nc_15-01-05kj.jpg
If you have any other questions or need help with the editing, email me through the contact option!
Good luck,
Sebastian
I guess that's what happens in the end, you start thinking about the beginning.
airkas1
Crew
Tue Jan 18, 2005 10:23 pm
Florian - Thanks, I was wondering about that Smile
Mick/Sebastian - Thanks to you both aswell.
I didn't see the spots/marks yet on Max, but I'm currently at school and we don't have the best computers here. I'll take a close look once I get home, same goes for all of the other pictures.
I'll redo the editing on the BA shot, so it doesn't get oversharpened. I didn't use neatimage.
I'll also fool around in photoshop to see if I can clone the spots away.
Thanks for explaining why those links didn't work Smile
Thanks again,
Kas
by123a
Wed Jan 19, 2005 12:33 am
Hi Kas,
I've been photographing aircraft for the past 40 years and thought I knew a thing or two about how to do it. Alas, since I've been submitting shots to A.net I realise I'm still wet behind the ears with nearly all my shots being rejected. "Baddirty", "badsoft", "badjagged", "badgrainy", you name it my shots have it. To my untutored eyes your shots look great and short of opening the shots up in Photoshop and tweaking with the levels it would be hard to spot the "dirt".
Assuming that you are using a digital SLR and want to check the sensor for cleanliness, stop the lens down to f22 or more and photograph a blank light wall out of focus. Spots on the sensor will then become more visible and I would suggest you use a blast of canned air about two inches from the sensor in an attempt to displace them, and not a soft brush as some user manuals suggest.
Keep snapping, I will and I'm sure we'll get there in the end.
Steve.
LHSebi
Wed Jan 19, 2005 12:34 am
Kas,
Sure thing. Hope I helped!  Smile I just realised that my edited links in fact do not work...I get the "It seems you're lost..." message. Odd...it used to work!
Sebastian
airkas1
Crew
Wed Jan 19, 2005 12:52 am
Steve - Thanks for explaining how I can clean my sensor. I forgot to ask that question Smile
Sebastian - Ah well... I just noticed the missing page, but it was worth a try Smile/happy/getting dizzy
Kas
sulman
Wed Jan 19, 2005 1:02 am
Kas,
Take care with the sensor; try a blower at first. Don't physically touch the sensor at this stage. Follow the instructions in the 300D handbook to find out how you access the sensor.
James
LHSebi
Wed Jan 19, 2005 3:41 am
Regarding the can of air, I heard this was not such a good idea. One of those cans will have some sort of propellant as well, which could produce moisture on the sensor which is NOT what you want! I don't know what they're called, but try to use something that just blows "regular" air out...anything with a manual pump for that matter.
What I have actually used, which worked quite well, is this little tool used in soldering. It is used to suck in any of the excess soldering metal when using it. It works wonderfully as you can just use it to blow air onto the sensor!
Don't try to blow on it yourself (through your mouth), as you can never be sure you are not also spitting on the sensor  Big grin.
Good luck,
Sebastian
dendrobatid
Wed Jan 19, 2005 3:59 am
I cleaned my sensor with great trepidation last week for the first time after noticing a couple of dust spots, one of which almost touched the An12 I had waited in the cold for so long for. I was able to totally remove it with the clone tool.
I used a foot pump as used to inflate dinghies and such after a recommendation from a friend.
This leaves one hand for the camera, one for the air nozzle and a foot to pump.
Pleased to say it worked well.
Mick Bajcar
BA747-436
Wed Jan 19, 2005 4:14 am
"I used a foot pump as used to inflate dinghies and such after a recommendation from a friend."
You used what?! Hahaha.
Dan Valentine - Bad Ass MOFO Photographer
chris78cpr
Wed Jan 19, 2005 10:07 pm
I have heard of people saying they used them, but i have always been worried as bits of dirt and grit can easily get clogged in the pumps outlet! I would hate to launch a small piece of grit onto my sensor at 100mph!  Sad
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
