mas a330
Rejections Help?
Mon Jan 24, 2005 4:08 am
hi, i got these rejections some of them after reading the rejection reasons i agree with them, but some of them seem a little weird to me. just want to know what you guys think?
http://www.airliners.net/procphotos/rejphoto.main?filename=9M-MKI-210105-fnd.jpg badcenter (is it really THAT bad)
http://www.airliners.net/procphotos/rejphoto.main?filename=9M-MKR-210105-fnd.jpg baddistance
http://www.airliners.net/procphotos/rejphoto.main?filename=JA8188-210205-fnd.jpg baddouble ??
thanks in advance
LHSebi
RE: Rejections Help?
Mon Jan 24, 2005 4:32 am
Hi,
The first one...its a nice shot, but definitely badcenter. Crop it closer on the sides, and a little at the top and it should get in!
The second one...loooks similar to the first one. Try cropping closer to the plane, and it should be ok.
The third one...baddouble is very odd...must be a mistake. I think it would be rejected for badexposure though, since it is a little overexposed.
Good luck,
Sebastian
I guess that's what happens in the end, you start thinking about the beginning.
INNflight
Mon Jan 24, 2005 4:37 am
First one badcenter but also a bit overexposed & oversharpend!
Second one clearly baddistance but also badquality.
Are you sure 3rd one is baddouble? Not very likely as you don't have any image in the DB so far...
Uploading to myaviation.net might be a solution for you.
Florian
Jet Visuals
mas a330
Mon Jan 24, 2005 4:41 am
thank you guys, for your quick response..
i will try again..
Users browsing this forum: Google Adsense [Bot] and 1 guest
