javibi
RAW Format Photo Viewer
Fri Feb 04, 2005 1:01 am
I am changing from JPEG to RAW these days, and I wish to know what program would you recommend as a photo viewer compatible with Canon .CR2 format. (I use PS CS for editing)
Thanks a lot
j
chris78cpr
RE: RAW Format Photo Viewer
Fri Feb 04, 2005 1:04 am
Try Ifranview, it might work, it opens most file formats!
http://www.irfanview.com/
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
Airplanepics
Fri Feb 04, 2005 1:43 am
If you use Photoshop CS already, use the built in RAW viewer and editor, I can't find one that's better anywhere!
Simon Nicholls
Simon - London-Aviation.com
chris78cpr
Fri Feb 04, 2005 1:49 am
I have heard CS is a pain when you want to cycle quickly thru files checking them for sharpness etc.
I can't afford CS right now so i dont know.
Chris
Airplanepics
Fri Feb 04, 2005 1:55 am
Ive never had a problem, other examples included BreezeBrowser ect.
Woody001
Fri Feb 04, 2005 3:36 am
Within the PhotoShop CS optioons page there is an option to view previews full quality or something similar (I've not got CS at work to check) if this is checked then it will take longer to bring up the preview image.
Breezebrowser is far quicker at running through shots to delete bad images.
Ian.
If I could just get the afterburner working...
ChrisH
Fri Feb 04, 2005 3:38 am
yeah breezebrowser is good for quick browsing
what seems to be the officer, problem?
IL76
Fri Feb 04, 2005 3:40 am
I just the browser in PS CS. You get thumbnails and a bigger preview. If you want to see it full size, you just open it in the RAW converter and go for 100%size. It's not that slow...
Eduard
mygind66
Fri Feb 04, 2005 6:11 am
Eduard..
Probably you have a good processor but if you just want to check fast a set of pics Breezebrowser is the best. Acdsee is good as well but slower when Raw files are seen.
Enrique
wietse
Fri Feb 04, 2005 7:11 am
Definately. Breezebrowser is by far the fastest for browsing the images to look at sharpness etc. You can easily copy the image to a different directory if the are approved by you.
Wietse de Graaf
Erwin972
Fri Feb 04, 2005 9:10 pm
http://viewraw.photosapien.com/
Kind regards,
Erwin
My gear: Nikon, Sony, Red, Sachtler etc.
ChrisM001
Fri Feb 04, 2005 9:55 pm
I use Breezebrowser, a great tool for quickly reviewing RAW images before you spend time copying and editting them.
mygind66
Sat Feb 05, 2005 1:54 am
Erwin..
Thanks for the program..Looks pretty nice but I'm afraid is only for nikonians. It doesn't work with Canon RAW files..
Enrique
javibi
Mon Feb 07, 2005 3:08 am
Thanks a lot to everybody for your help.
j
