pilot kaz
Another Non Pro Needs Help :P
Fri Feb 04, 2005 7:38 am
Hey guys, sorry for another topic but I would like to get this shot online  Smile
ok to start off I did not even have a rejection email so I do not know why it was rejected but here it is..
http://www.airliners.net/addphotos/rejections/big/nwadc10amsweller2.jpg
any advice?
If people are annoyed with these thread because there is a lot of them just tell me and I will suggest deletion  Smile
Thanks very much  Smile
Kazzie x
Newark777
RE: Another Non Pro Needs Help :P
Fri Feb 04, 2005 7:42 am
You can go to http://www.airliners.net/myphotos to check why your pics were rejected.
As for the photo, the first thing I noticed was that it appeared a bit oversharpened. If you look around the edges of the second window from the left, you will see what I am talking about. It might also be rejected for badmotive, since it is just a shot of the cockpit windows, and the pilots don't appear to be doing anything special.
Harry
Q330
Fri Feb 04, 2005 7:59 am
I think it's most likely a badmotiv rejection. Could possibly be badquality as well, but why don't you check the link that Newark777 posted and tell us for sure.
-Q
Long live the A330!
pilot kaz
Fri Feb 04, 2005 8:03 am
Ah it was a bad motive Rejection  Smile oh well better luck next time  Smile
jfktowerfan
Crew
Fri Feb 04, 2005 8:05 am
Kaz,
A few things stick out, first its off center which causes the second issue those carts in the back grab your eye more than the aircraft.
Check out the other nose photos in the DB. If this shot had more of the nose showing it would be good, but this one is just kinda blah...it doesn't grab you like a close up should.
Corey
C'mon Man
IL76
Sat Feb 05, 2005 7:36 am
BTW... Maybe besides it being bad motive, the horizontal/vertical size ratio is too large. Crop your pictures anywhere between 1024x683 (3:2) and 1024x768 (4:3) and you're alright.
Eduard
DLKAPA
Sat Feb 05, 2005 9:10 am
Personally I like the carts in the background. It ads depth to the shot rather than just an empty space.
Users browsing this forum: ANA787, Kaphias and 1 guest
