C133
Comments Appreciated On This Rejection
Sat Feb 26, 2005 8:04 am
badqualitybadexposurebadjagged:
http://www.airliners.net/addphotos/rejections/big/HL741812204rotc.jpg
I'm somewhat new at uploading but have been lurking the forum for a couple of years. Is this image really THAT bad? I'll move on, but would like to learn from this one if I can. Thanks in advance.......
Terry
Fine: Tax for doing wrong. Tax: Fine for doing well.
INNflight
RE: Comments Appreciated On This Rejection
Sat Feb 26, 2005 8:11 am
Hi Terry,
The motive is nice, but the photo was ruined by heat / haze impact. The air wasn't very clear on that day and sharpening resulted jaggies, take a look at the small black cheatline and the stripes on the tail!
Badquality is also because of the grain caused by heat / haze in the air.
I guess badexposure because the gears are too dark. I guess you underexposed?
In all, the motive is nice, you know how to edit properly but it just wasn't a good day for shooting. Too hazy, you can't fix that in any way.
Maybe next time go out in early morning / late afternoon so air is a bit cooler than during the day.
Good luck!
Florian
Jet Visuals
A346Dude
Sat Feb 26, 2005 8:17 am
Terry,
No, the photo isn't terrible, but it could be improved somewhat. The overexposure can be seen quite clearly at the top of the engines, where the grey "lines" have disappeared due to being blown out.
As for the badjagged, I think it refers to the lines on the tail; they are not perfectly smooth. Might want to try using layers to avoid sharpening the tail as much as the rest of the plane (to be honest I don't know how to do this myself!).
One more thing, the colours seem somewhat dull, perhaps try boosting the saturation a little.
All that being said, the overexposure probably prevents it from being accepted, unfortunately. Try again and keep working at it.
A346Dude
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
Psych
Sat Feb 26, 2005 8:22 am
Hi Terry,
I think the cheatline going down the side of the fuselage is where the jaggies are noticable. I find this often occurs with aircraft that have such straight lines in their livery. Then, when they are at an angle, the jaggies appear - especially following some sharpening.
But I think the killer blow is the heat haze. This prevents any real clarity to the image. I think that is the kind of problem that no amount of post-processing skill can resolve.
One for the personal collection, as they say. Hopefully better luck with the conditions next time (though I wouldn't say no to a bit of heat haze here - we're a bit cold in the UK at the moment).
All the best.
Paul
C133
Thanks, Florian. Shooting from Imperial Hill is tough due to the distance involved. Other guys (Mike Carter, Ben Wang) seem to pull it off in the same conditions, but I do think bad air is a large part of my problem. As to the dark gear, maybe CS' highlight/shadows can help; will have to experiment with that. Thanks again.
Terry
LeanOfPeak
Sat Feb 26, 2005 8:27 am
BadExposure:
Blown highlights on the wing/fuselage fairings and the #1 and #2 engine nacelles. You can slightly underexpose to avoid the blown highlights and then bring up the midtones in post-processing. Shooting with a strongly directional sun doesn't help much either.
BadJagged:
There are some sharpening artifacts (Mostly along the black line down the middle of the fuselage). More careful/selective sharpening should take care of that.
BadQuality:
Because this one can't be saved without going back to the original image. And given the heat haze and the blown highlights, I'd suspect it can't be saved at all.
A nice effort, and one that is worth keeping on file, but I would suspect it was probably the blown highlights that really knocked it out.
[I am not a screener]
C133
Sat Feb 26, 2005 8:41 am
Thanks all for the good suggestions. I have to smile at one opinion of over exposure and another of under!
I've taken to shooting exclusively in RAW for max post processing capability, but find that with constant take-offs and ground movements in this area of LAX the air is rarely good enough for lift-off shots like this. I'll just have to keep at it and be more selective in what I think makes the grade for upload. You guys are sharp on the fine points and I'm glad I asked for your help. Thanks again.
Terry
jumbojim747
Sat Feb 26, 2005 7:01 pm
Hey terry its a great shot but like others said it let you down in some areas.
What camera and lens are you using ?
Keep up the great work and good luck in future uploads.
On a wing and a prayer
C133
Sat Feb 26, 2005 11:44 pm
It's a D70 and the Nikkor 80-400VR. I've even wondered if a 300 or 400 2.8 (at around US $4,0000, not that I can afford that) would help much with any of this, but don't think so. LAX is so restricted for photography that Imperial Hill is the only spot I know of to get lift-off shots, and it's simply kind of far when you throw in the effect of constant huge volumes of jet exhaust laid down by all the departures. Some luck is needed for a break with clean air.
That's my theory, anyway. As I've said, others do better with the same situation, and I bet they work harder at it. I will keep trying--I can't move to Amsterdam!
Thanks for the encouragement.
Terry
